warning light indicator help
2008 ES 350. Had all 4 tires replaced on Wednesday (4 days ago). This morning, i see 3 warning lights and "Check VSC". The three lights are: The yellow "check" engine light (malfunction indicator); the yellow car with the wavy tire tracks behind it and the third was the red yield sign. I called lexus and they said that I need to bring the car in ASAP????. I was hoping the issue was related to the installation of 4 new tires. Any ideas??
Either bring it to an auto parts store and have them scan it for a code or bring it to the dealership. With the VSC light being on, the basic scanner that most Autozones, and similar, use might not be able to bring up the proper code. ABS and traction codes usually require the better scanners.
thanks Nick, I will do that. Scheduled for tomorrow. Interestingly, all the lights are now off and the car is doing fine. Will bring it in anyway, just in case.
Thanks
Thanks
jcm505
ES - 5th Gen (2007-2012)
03-01-14 12:44 PM
