cant hear radio with rear defrost on ??
You have some interference between the FM receiver and the rear heater.
Antenna is built into the rear glass, just like the defroster is. Perhaps the rear defroster is damaged in some way...? or maybe someone managed to put one of the defroster lines on to the antenna... somehow...?
Removing rear window tint often damages the defrost "wires" on the glass. I had a similar problem with one of my cars. If you are lucky and the damage is minor, it might be repairable with a kit sold on line. If the damage is major (most likely) the only fix is to replace the rear window.
