ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
AFS flashing and rear suspension thunk
Old 10-28-14, 10:09 AM
nevernu
nevernu's Avatar
Default AFS flashing and rear suspension thunk
AFS Flashing and there is a clunk in the right rear on turns and it bottoms out over speed bumps . According to service manual and internet search, this combo may be a problem with the rear height control sensor sub assembly or rear No. 2 suspension arm or other suspension issue. AFS flashes because the car height changes affecting the headlight adjustment leading to AFS flash.
Dealer says "Yes sensor is mounted to the control arm and if it's broken in half, it would clunk and cause afs light to flash."
Just another passage in the life of this vehicle. We'll see what they say when I bring it in next week, especially interested if its still covered under my rapidly expiring extended warranty
Old 11-05-14, 08:58 AM
nevernu
nevernu's Avatar
They found rear headlight leveling sensor to be seized and replaced under extended warranty. No broken suspension parts. A $387 Sewell part.
Old 12-09-14, 03:30 PM
nevernu
nevernu's Avatar
and a little update, the rear end clunk turned out to be worn sway bar bushings replaced under extended warranty..... a month later
pvvdds
03-09-17 09:13 PM
RAWKUSsd
09-18-15 04:35 PM
biacs
07-06-15 01:36 PM
wMetz
09-11-13 08:55 AM
Agombos
GX - 1st Gen (2004-2009)
15
07-23-11 12:41 PM
Quick Reply: AFS flashing and rear suspension thunk
