ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
20" x 8.5" rim offsets for 2007 ES350
Old 03-06-13, 05:31 PM
ChristianM
ChristianM's Avatar
Smile 20" x 8.5" rim offsets for 2007 ES350
Hey everyone,
I have debating getting the lexani lss-8 for my 2007 ES350. I was wondering what offsets people have gotten away with and no rubbing issues, stock ride height. I'm pretty sure the rim shop was selling me 255/35/R20 Goodyear Eagle F1 tires.
Anyone have a similar size tire on 20" rims? or similar sized rims/offsets and care to comment on the rubbing issues? Any feedback would be great. I'm going to keep searching the forum in the meantime.
Thanks
Old 03-07-13, 03:50 AM
xanderES
xanderES's Avatar
Since you are going with 8.5 widths I am assuming you're trying to at least have the wheels not poke past the fender. If this is the case, you'll be looking at 35-40 offset with a 235 series tire. Shouldn't have much trouble with that setup at stock height. I know those specs will work without much problem.
Pics after you get them installed!
Old 03-07-13, 08:04 AM
jcat_350
jcat_350's Avatar
Your car will ride horribly with wheels that large, fair warning.
With a 35 series tire at stock height you probably won't have rubbing issues except when turning full lock, especially with a 255 tire. The car will however look like a 4x4.
A 235 on an 8.5 will be stretched, and will cause more harm than good.
Old 03-10-13, 05:56 AM
xanderES
xanderES's Avatar
I definitely agree with jcat in regards to the roughness of the ride and wheel gap. Even with the stock suspension you will feel a very large increase in the amount of road feedback (bumpiness). With 45 series tires I felt only a very slight increase in this (stock suspension). With coil-overs it is quite noticeable with my (8,6) spring rates. If not for running almost full soft I would say that I would not use it as a daily driver due to its decrease in comfort level.
Less sidewall = less vibration absorption
Regardless, I will post some very useful websites for future seekers of wheel fitment.
http://willtheyfit.com/ - stretch circumference references and wheel depth
http://www.1010tires.com/Tools/Tire-Size-Calculator general tire circumference (without stretch or wheel depth)
Old 03-10-13, 10:46 AM
LexRuger
LexRuger's Avatar
That tire size is too tall and probably too wide. You'd need a 225/35. And you could use up to a 9" wide wheel. Whether or not it will look like a 4x4 is personal preference. I've seen plenty of previous gen ES's with 20s and they looked fine to me.
Old 03-11-13, 09:40 AM
ChristianM
ChristianM's Avatar
Thanks for the input, I just did a test fit with the 255/35's and they cleared, so far atleast. Im waiting for the winter to finish before i put them on and i will post the pics then. If they d rub after installation, i will likely head to the 235/35.
During the test fit, i didnt think the car looked like a 4x4 although i have seen a few ES's with that look. Personally, im not a big fan of that, im trying to keep the car relatively subtle.
Thanks for the info everyone.
Old 03-11-13, 01:20 PM
SICK350
SICK350's Avatar
Hello, I had 225/35R20 Nitto tires on a 8 inch width rim on my 02 es300 (factory suspension), I had no issue with rubbing or the ride. The only difference is you really have to watch the pot holes due to smaller sidewall.
As for the 07 es350 I plan on running 22's and Coilovers.
The photo is after coilovers were installed and fenders were rolled.
Old 06-27-13, 06:33 PM
it4me
it4me's Avatar
Hi
Here is my set, maybe will help somebody:
19 stance evolution rims
245*40*19 front 8,5 offset35
255*40*19 rear 9.5 offset 40
Personally I 90% like it, but it is kinda still wide...
Even i rolled rear fender a little, rear wheels rub a bit when you have 4 passengers and there are some bumps.
I would better go with:
235*40*19 front 8
245*40*19 rear 9
good luck!
Old 06-27-13, 06:55 PM
jcat_350
jcat_350's Avatar
Originally Posted by it4me
Hi
235*40*19 front 8
245*40*19 rear 9
good luck!
If you went with a 35 instead of a 40 in the rear, it'd eliminate your rubbing issue. By using a 40 on a 255 your overall diameter is a good bit larger than the front.
245/40/19 in the front and 255/35/19 rear will be wide enough to avoid too much stretch but not so tall that you have clearance issues especially since you already rolled the fenders a bit.
Old 06-27-13, 09:04 PM
LexRuger
LexRuger's Avatar
Hi
If it bothers you a lot and you don't wanna change tires you could change the offset of the wheels. (Assuming there's enough extra metal on the back of wheels)
Old 06-27-13, 09:07 PM
1sWt2GS
1sWt2GS's Avatar
that is one of the nicest ES ive seen on the forums
looks like that can definitely mess with the integrity of the wheel.
Old 06-28-13, 05:55 AM
jcat_350
jcat_350's Avatar
If it's done right it won't weaken the wheel. However to get the effect that it4me is probably looking for he'd need to take off more than is advisable.
Old 07-01-13, 07:10 AM
it4me
it4me's Avatar
Yep, this will be next step...i'm already looking for other rear tires...thanks
Bubb141
01-27-14 11:12 PM
561Lexus
07-28-13 06:50 PM
showboat
08-12-08 09:41 PM
jg 368 48
RX - 1st Gen (1999-2003)
04-30-07 10:57 PM
AZGS400
Wheels, Tires & Brakes Forum
09-27-02 04:13 AM
Quick Reply: 20" x 8.5" rim offsets for 2007 ES350
