Oil leak, HELP, (pictures provided).
You're going to change the pump?? For Pete's sake.......the darkening of the PS fluid is normal and in no way indicates a pending failure of the pump, nor will it likely cause a pump failure. Just suckout and refill (and drive) the reservoir in three steps and carry on driving the car. The "brighter" fluid colour may also aid you in finding the location of the leak.
Suck out the fluid from the reservoir, refill with new specified fluid (probably Dexron ll or lll, but check your Owner's Manual) to the Full (cold) mark, and then go for a drive. Repeat three or four times. Stay away from the purging the fluid by running the engine method that you'll find on the web. How many kms on the car?
Confirmed as a CV boot leak and what we saw was the grease spray when the car was in motion. Was told if not under warranty it would've been 550$ of which almost completely comprised of labor costs. Luckily I am still covered under the manufacturers power train warranty.
