ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Torque Spec.
Old 05-13-11, 06:30 AM
j.tom
j.tom's Avatar
Default Torque Spec.
Can anyone please tell me the Torque specs for the caliper bracket bolts(front and rear caliper brackets) a pdf will be great,Thanks!!!
Old 05-13-11, 06:32 AM
j.tom
j.tom's Avatar
It's for 2008 ES350..Thanks again!
Old 05-13-11, 02:18 PM
lamikela1
lamikela1's Avatar
Here are the factory specs for both.
File Type: pdf
File Type: pdf
Old 05-13-11, 05:37 PM
j.tom
j.tom's Avatar
lamikela1...Thank You So Much!!!
Old 05-13-11, 05:49 PM
j.tom
j.tom's Avatar
lamikela1...I need The Caliper Bracket/Torque Member Bolts spec's
Old 05-14-11, 05:09 AM
j.tom
j.tom's Avatar
Can anyone help??? Thanks!
Old 05-14-11, 09:04 AM
the.wong.k
the.wong.k's Avatar
all brake component bolts at 25ft lbs of torque, it's basically hand tight......
Old 05-14-11, 09:13 AM
j.tom
j.tom's Avatar
Nobody knows what a caliper Bracket is?The two bigger bolts that you need to take off when you need to replace the rotors,They need to be more/way more then 25ft lbs.
Old 05-14-11, 12:44 PM
the.wong.k
the.wong.k's Avatar
yes i know what it is, it should be hand tight. but if you really want the torque spec, i'll get it to you by monday
Old 05-14-11, 01:58 PM
j.tom
j.tom's Avatar
the.wong.k..That Will be Great...Thanks!
Old 05-16-11, 02:52 PM
lamikela1
lamikela1's Avatar
OK, I think this is what you need.
File Type: pdf
File Type: pdf
Old 05-16-11, 02:59 PM
the.wong.k
the.wong.k's Avatar
looks like he got it
Old 05-17-11, 05:41 AM
j.tom
j.tom's Avatar
YES.lamikela1..Thanks Guys...Greatly Appreciated!!!
Old 07-03-14, 11:11 AM
007's Avatar
Thanks
Old 02-21-16, 12:14 PM
pasica
pasica's Avatar
2011 Lexus RX350
Can anyone please tell me the Torque specs for the caliper bracket bolts (front and rear caliper brackets) a pdf will be great, Thanks!!!
Quick Reply: Torque Spec.
