ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
ES 350 Rear Window / 3rd Brake Light RATTLE
Old 10-08-10, 12:41 PM
Romil
Romil's Avatar
Default ES 350 Rear Window / 3rd Brake Light RATTLE
I recently bought a pre-owned 2007 Lexus ES 350, only 30K miles. I am hearing an annoying rattle coming from the rear window / 3rd brake light. I gave it to the dealer to look at but they thought it was from inside the trunk and said the jack wasn't secured. Nonetheless, that wasn't it, and the rattle continues. I know it's coming from inside the cabin, not in the trunk. It alsmost seems like the 3rd brakelight is rattling or possibly hitting the rear window?
You almost need someone else to drive the car and get to the rear. I pressed around on the 3rd brake light when my wife was driving the car and it could possibly be something in that area.
Any suggestions or anyone experiencing this?
Old 10-09-10, 12:53 PM
YotaCarFan
YotaCarFan's Avatar
IIRC, there's an issue with the radio antenna signal amplifier vibrating on that car. It's a small electronic module inside the right rear quarter panel. The fix is to replace it's bracket with a stiffer one. There should be a TSB on this.
Old 10-10-10, 09:07 PM
Blueshark
Blueshark's Avatar
Also, look at your rear middle roof light, that is what making my car rattle. Either the lamp is not clipped proprely, easy to test or simply pull down the roof lining and put foam on the Tire pressure module, the lamps tend to tap the module and make a metal buzzing.
Yes, it does resonate in the rear and people will think it is the rear deck or the rear window.
Hope that help. Also, i think there is a bulletin on this as i printed to show to the dealership.
Old 10-21-10, 12:17 PM
turbomac
turbomac's Avatar
I had the exact same issue, same car. Took it 3 times to dealer, the 4th time they took apart the rear window and replaced it with a new one. Problem solved!
I had an es 350 2010 loaner for 3 days and it makes the same rattle noise on the back window. Now im trying to figure out my drivers window as it makes a noise they couldnt repair. Ahh how frustrating..
Fla14Ls
10-06-18 10:08 PM
Ken167
12-29-16 04:06 PM
Maserati
SC- 1st Gen (1992-2000)
12
10-24-14 11:20 AM
paul1
11-18-13 01:43 PM
Quick Reply: ES 350 Rear Window / 3rd Brake Light RATTLE
