ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Only 29 Highway MPG for 08 ES 350
Old 12-01-08, 11:28 AM
waymay1305
waymay1305's Avatar
Default Only 29 Highway MPG for 08 ES 350
On a recent trip between Dallas and Houston which was about 270 miles each way, I only averaged 29 highway mpg. Is this good, bad or indifferent? If bad, how do I improve that? My average speed was between 75-85 mph depending upon traffice conditions. Also I only have 2000 miles on my car. Thanks.
Old 12-01-08, 11:29 AM
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
That's actually pretty good.
Did you have the cruise control engaged?
Old 12-01-08, 11:36 AM
LexBob2
LexBob2's Avatar
The ES350 is rated by the EPA at 27 mpg highway, so 29 mpg at 75-85 mph isn't bad at all IMO.
I get 30-32 mpg at speeds under 70 or so.
Probably the best way to improve your mpg are slower speeds, in the 65-75 mph range.
Old 12-03-08, 10:13 AM
fly2m51
fly2m51's Avatar
What kind and grade of fuel are you guys burning. Im seeing the same out of mine and I've been running regular. I just finished running a couple of tanks of premium with no improvement, maybe a little less. I have noticed a difference in different brands of gas. some do show improvements over others. But over all the care gets great mpg and if you can keep your foot out of it, it will surprise you. I have found that I can do better than the cruise control by accelerating on the down hill and decelerating on the up hill.
Old 12-03-08, 02:39 PM
oldcajun
oldcajun's Avatar
At those speeds, that is very good mileage for a car this size. You might get a slight improvement with more miles on the car, but it won't get a lot better. If you drove at 70 mph, you would be getting mileage in the low 30 mpg range. Can you get any better? You could switch to synthetic oil, set tire pressures to 35 psi, and run with the air conditioner shut down and maybe get another 2 mpg or so. I have friends with a VW with a 4 cylinder engine who get slightly worse highway mileage than my ES350.
Steve
Old 12-10-08, 08:08 AM
jeffofla
jeffofla's Avatar
The average speed is the culprit. Average 60-65 and you would be amazed at the increase in fuel efficiency. I've found I get my best gas mileage in that range. Going 75-85 and getting 29 MPG in a Lexus is phenomenal.
Old 12-13-08, 04:39 AM
Macklin
Macklin's Avatar
A lot of folks have reported better myself included. We just did a trip to Pittsburgh for Thanksgiving. I got a tad over 30 heading up there into a stiff head wind the whole way and white out conditions through the mountains on the Pennsylvania Turnpike. (I have a new loathing for that highway as we almost got rear ended by a 16 wheeler.) Got about 32 on the way home in much better conditions. Probably averaged about 70 mph both ways.
I did see 33 on one trip home from there. All actual mileage, not computer.
Old 12-13-08, 11:56 AM
superchan7
superchan7's Avatar
I can probably do 28 mpg at 70-80 mph. If I drop the speed down to 65, the mpg soars to well over 30.
Old 12-13-08, 12:08 PM
RXGS
RXGS's Avatar
WOW if thats bad, i don't know whats good, our 2001 es300 only gets 26 mpg highway at its best
Old 12-14-08, 02:25 PM
Macklin
Macklin's Avatar
Did something change from '98 to '01? My '98 would typically get 30 on the highway...in good weather. And I averaged 24/25 in town including some interstate to and from work.
That was over the 9 plus years I owned it. It was one of the reasons I decided to buy a new one.
I'm **** about gas mileage. As a boat freak...I've learned how to be.
Old 12-27-08, 10:25 AM
RXGS
RXGS's Avatar
^^^^ Its quite cold here, i am sure that has something to do with it, maybe the gas? Who knows
Old 12-28-08, 11:18 AM
RobF350
RobF350's Avatar
people should report if they are using ethanol added gas or not.
I have gotten over 30 ( 33 ) but that was really paying attention to the car, not going into passing gears, no heavy throttle, taking my foot off the gas going downhill and easing into the throttle going up hill, and staying under 70mph.
We have fairly flat roads here, and I always use 87 octane with 10% ethanol.
Old 12-28-08, 01:02 PM
RXSF
RXSF's Avatar
the ES gets surprisingly high mileage for 270 horses. it does rather well for itself. the 3.5 in the toyo/lexus lineup is a gem.
Old 12-28-08, 08:32 PM
RXGS
RXGS's Avatar
^^^ Besides for the diesel noise on startup haha
Old 12-29-08, 07:06 AM
garsarno
garsarno's Avatar
Got low 30 mpg from Wilkes Barre to Cleveland, going 70-75 mph and filling up to the max upon departure and arrival (nursing as much fuel as it would take).
Quick Reply: Only 29 Highway MPG for 08 ES 350
