ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Enabling the NAV system features when driving
Old 11-21-11, 07:12 AM
  #121
fcyam
fcyam's Avatar
Smile Enabling the NAV system features when driving
Originally Posted by amf1932
That photo says it all...........good job!!!
Thanks to Dreyfus and AMF1932, I pushed a credit card into the gap between the "Lexus" cover and the "buttons" cover. Lift up on the credit card and the cover released. Now it seems so easy.
Old 02-04-12, 08:20 AM
  #122
retiredva
retiredva's Avatar
Default Nav update
Recently purchased a certified 2010 ES 350. Has the 9.1 Nav. version. Want to update to the 11.1 version. Any way of legally doing that w/o paying the dealer $250 to buy and install? Anywhere else to buy? Saw the post about prying off the front cover to get at the DVD insert. A helpless person like me will probably break the plastic, but guess I could try.
Many thanks!
Old 02-04-12, 08:49 AM
  #123
LexBob2
LexBob2's Avatar
Many thanks!
I haven't heard of anyplace to get the 11.1 update anywhere other than the dealer. The new gen Camry has a HDD system like your car (no DVD) maybe a Toyota dealer can do the upgrade for a little less than at Lexus but not sure.
Old 02-06-12, 05:08 AM
  #124
fcyam
fcyam's Avatar
Many thanks!
The 3/4" cover below the NAV screen has a narrow gap between it and the cover below. I inserted 2 credit cards into the gap and pushed up on the cards. The cover comes off easily. In the menu, eject the DVD and replaced with the new one. That's in my 2007 and not sure if the 2010 is the same. I bought my DVD disk on eBay for $169. Not sure how things work in a 2010, later models may have hard drives.
Old 02-12-12, 03:17 PM
  #125
jerfitz
jerfitz's Avatar
Sunday - 2/12/2012
Hi folks, thought I would drop by because I just purchased the latest NAV disk for our 2007 ES350.
It is disk U36 D, PT219-GEN05-11, (Ver 11.1)..
I removed it's Ver 11.1 loading.kwi file and re burned it with the old Ver 5.1 loading.kwi file in its place. It still works great. Now when I am driving my wife can reprogram GPS destinations while the car is moving and vice versa.
It even installed easier. For those of you who already have a modified disk installed that is using the old Ver 5.1 loading.kwi file all you have to do is remove your current NAV disk and insert the new Ver 11.1 NAV disk and it starts the first time. No disconnecting the battery cable to deplete the NAV system memory because the 5.1 loading.kwi file already in the NAV memory from your previously modified disk is identical to the one on the re burned Ver 11.1 disk. BTW, if it does not start up immediately turn off the ignition, wait a minute or two, and then turn it back on to restart/reboot the NAV system.
Whoever wrote those original instructions on how to burn and install the new disk did a great job because after all this time even I had to use them. (:
JerryF
Old 02-12-12, 05:32 PM
  #126
amf1932
amf1932's Avatar
Is this a genuine NAV disc, or is it a counterfeit ?
Old 02-13-12, 12:25 PM
  #127
jerfitz
jerfitz's Avatar
amf1932,
I don't know. How can you tell? I included a photo of the exact disk I received.
BTW, the disk I received has all the official printing and background color on it that is on my version 9.1 NAV disk that I purchased from my local lexus dealer. I never did update to the Version 10.1 NAV disk.
Best regards,
JerryF
Attached Thumbnails Enabling the NAV system features when driving-disk-u-36-d.jpg
Old 02-13-12, 12:31 PM
  #128
LenniePaz
LenniePaz's Avatar
Originally Posted by jerfitz
amf1932,
I did notice that in my original post the web site URL address from where I purchased the disk no longer goes to the ad so I deleted the mention of it from my original post. Someone changed something!
Best regards,
JerryF
It looks like a printed disc to me. Is there a hologram ring in the center? When you move the disc around,does the hologram change color?
Old 02-13-12, 12:57 PM
  #129
jerfitz
jerfitz's Avatar
All three of my disks 6.1, 9.1, and 11.1 look the same. They all have a mirror finish on the inter-ring in which I can see my face and I do not see a hologram moving around in any of the three disks. BTW, 6.1 came with the new car, 9.1 from an official Lexus dealership and 11.1 was purchased over the internet.
Old 02-13-12, 01:38 PM
  #130
amf1932
amf1932's Avatar
I am still sort of suspicious, especially because of the extremely low price you paid.
Also, some good quality counterfeit discs are very hard to tell from the genuine article.
In any case, good luck.
Old 02-13-12, 04:24 PM
  #131
michaeljf
michaeljf's Avatar
Default Disable Nav lockout in 2012
Anyone figure out how to disable the Nav (and other features) lockout in the newer models, like 2012 ES-350? Apparently the current problem is that the newer models use a flash or harddrive rather than a disk. If I recall correctly other manufacturers systems can be disabled electrically. Any thoughts on that possibility here?
Any chance someone has the wiring diagram for the 2012 radio/nav system? .
Old 03-05-12, 02:54 PM
  #132
Bronbay
Bronbay's Avatar
I'm trying to find out if the Nav Overide with a Hybrid disc will work in a 2008 ES
Some people say yes and some say the Hybrid disc only works on 2007 and older models.
Can anyone here with a 2008 ES confirm if the Hybrid disc worked for them?
Old 03-17-12, 11:51 AM
  #133
jerfitz
jerfitz's Avatar
Bronbay,
Yes the Hybrid CD worked for 2007, 08, and 09 ES350s. When Lexus converted to a hard disk (no CD in the NAV unit) in 2010 model it no longer worked.
JerryF
Old 06-23-12, 11:56 AM
  #134
android943
android943's Avatar
Default A puzzle for all of you...
Okay, here's an interesting mystery. I burned a hybrid 11.1 disk with 5.1 loading.kwi. Wouldn't work at all, just kept getting the Japanese error message. So just to test the burning technology, I burned a copy of my original 7.1 disk, using Nero, and put it in, and sure enough, after about 10 seconds it went into the "LOADING" routine and loaded fine. I could then pop that disk out, and put in the 11.1 disk, getting the "Verifying DVD" message, and then I had the 11.1 maps and POI's, but no fingerdance override.
So I am puzzled. There seems to be no problem with my burning procedure or disks (DL Verbatim) but with a 5.1 Loading.kwi, none of the hybrid disks will load initially, although they will load AFTER another 7.1 or 11.1 disk loads with it's original Loading file.
Any thoughts? BTW, I have a 2008 ES350 ML audio model. I'd love to get this working before a road trip next weekend.
Old 06-26-12, 09:08 AM
  #135
bouncerhvj
bouncerhvj's Avatar
See the last post #270 on this page.
https://www.clublexus.com/forums/is-...av-dvd-18.html
They talk about setting the book-type to DVD-Rom on the burning software. I'm having the same issue as you are and will try this when I get home. I'm using imgburn as my software.
Quick Reply: Enabling the NAV system features when driving
