Another Fix?
E/W vs N/S engines.
That may well be why the ATF oil sump/pan is not deep enough to hold enough ATF for COLD operation. If you fill it completely FULL with COLD ATF it will be too full once the ATF warms to operating temperature. A deeper, not as shallow, sump could allow for maybe another quart of ATF.
But that would mean raising the entire transaxle to keep the gears from stirring the ATF into a foam, or lowering the bottom of the sump even closer to the roadbed.
Just a few of the relatively minor problems with FWD.
Is there any chance this flare problem only involves the new 6 speed transaxle?
More gears. more clutches, less room for an ATF sump large enough...
another thought...
Hydraulic pressure is used to engage the clutches and a return spring to release them and force the ATF back into the sump. The viscosity of the ATF while cold might be just enough that this return flow isn't quite fast enough to keep up with the ATF pump's capacity in certain shift sequences.
Iluvlexus
RX - 1st Gen (1999-2003)
07-09-11 06:43 AM
hcdesign
ES - 5th Gen (2007-2012)
19
02-10-07 09:13 PM
