ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Manual nav hack switch
Old 10-01-10, 12:24 PM
  #91
radiologym
radiologym's Avatar
Thanks, dreyfus, one cable was loose, now everything works, including switch
Old 10-20-10, 03:19 PM
  #92
qliu34
qliu34's Avatar
I have the same problem in my es350. Which cable did you fix? Please help. Thanks.
Old 10-20-10, 03:41 PM
  #93
radiologym
radiologym's Avatar
With gray connector, single thick wire. It was loose and fell inside the car.
Old 10-21-10, 04:20 PM
  #94
qliu34
qliu34's Avatar
Can the connector be seen in the picture in step 2 on page 1 of this thread? Is it the one on the bottom with single thick black cable? thanks for your help.
Old 10-21-10, 04:30 PM
  #95
radiologym
radiologym's Avatar
Yes, this is the one!
Old 10-21-10, 06:29 PM
  #96
qliu34
qliu34's Avatar
Thanks for the reply.
I took it apart again, and the my connector was not loose to begin with, and I still don't get gps siganls. Any other ideas?
Old 11-07-10, 09:14 AM
  #97
JFinn
JFinn's Avatar
Very cool.
Old 01-04-11, 02:57 PM
  #98
lauderdale
lauderdale's Avatar
Can someone confirm this hack will work in a 2008 ES350?
Old 01-12-11, 09:22 AM
  #99
dreyfus
dreyfus's Avatar
I can't positively confirm it but so far as I know no changes were made between 2007 & 2008 that would affect the manual switch.
Old 01-20-11, 01:46 PM
  #100
dickengel
dickengel's Avatar
Smile
It works great in my 2008 ES350 Pebble Beach
The hardest part was figuring out where to mount the switch. I pulled out the ash tray and mounted it towards the top of that cubby.
Kyle
Old 02-04-15, 01:09 PM
  #101
ThumperPup
ThumperPup's Avatar
when i go to have my Vais Technology unit installed for my audio and phone.
i am going to take this info to the shop and ask if they would do this for me whyll they have it out.
Old 02-25-15, 12:48 AM
  #102
ThumperPup
ThumperPup's Avatar
So today when i went to have my Vais Tech SL3B unit installed i also showed the tech at the shop
these instructions he did this i am happy that he didn't drill a hole in the area where it shows in the photo because the bypass didn't work exactly the way it should have not sure why it didn't he isn't sure either.
he put a 2 way switch a toggle button under the dash he did have to drill a hole right to the right of the AFS button is where he put the switch he fallowed the insturctions on the wire to cut and then run the switch to.
it worked for the bypass but it would now allow the speed signal to be reingaged also when it was bypass it only worked for the blacked out options to show and for me to scroll throught the audio files when in motion and play a dvd just to test it.
but it would not allow me to input options and info for navigation
so i he took the radio back out and just put the wiresback the way it was and no bypass i think i am just going to buy a vais tech bypass unlock unit and install it.
Old 12-08-15, 07:26 AM
  #103
Curlyp
Curlyp's Avatar
Dreyfus - thanks for the detailed explaination! Does this work for the 2010 model?
donmatt
RX - 4th Gen (2016-2022)
04-13-16 09:16 AM
EyeKutr
11-20-07 10:33 PM
sbrown02
01-08-07 09:53 AM
rschiff
02-23-05 03:23 PM
Quick Reply: Manual nav hack switch
