Can plastic radiators be repaired?
Old 02-10-17, 01:00 PM
franbev
franbev's Avatar
Default Can plastic radiators be repaired?
I've noticed a small crack on the top of the radiator on our '90 ES250. It's just starting to weep, is there any repair possible other than replacing the radiator?
Old 02-10-17, 02:39 PM
tomf
tomf's Avatar
Don't know if you can repair it. Why bother? If you are doing the repair yourself radiator are cheap: $60 to $130 at RockAuto.
Old 02-10-17, 05:17 PM
RXGS
RXGS's Avatar
I've seen JB weld and some types of epoxy used as short term repairs, and by short term I mean to allow the person to drive to the parts store or get off the highway, but I wouldn't suggest it as a permanent fix. Just pony up for the cheapest radiator and replace it as its cheaper than replacing the engine when you inevitably overheat the car with a temp fix.
Old 02-10-17, 05:56 PM
ES300NZ
ES300NZ's Avatar
Hi. yes you can repair that radiator. but there's no point.
That radiator started out being black, as time went by and hundreds of heat and cool cycles it went from black, to green to brown, to light brown. At that point it will start to crack on the inside, which is what all those lines on the outside are.
as soon as you repair that crack, another will appear within a day or so elsewhere (the next weak point). You'll be chasing them forever. It's cheaper just to replace the radiator.
Old 02-11-17, 12:47 PM
80es300
80es300's Avatar
rockauto has denso radiators for good prices and denso is toyota oem brand
fredcrn
01-24-15 01:27 PM
Measured
07-14-13 10:45 PM
pmpdaddyt
Performance & Maintenance
11-01-08 04:26 PM
setsuna57
04-27-08 09:17 AM
valley
06-16-03 11:25 PM
Quick Reply: Can plastic radiators be repaired?
