ES300 differential location? Front axle replacement
I am replacing the front LH/driver side CV axle. When I pulled the axle, quite a bit of fluid escaped. I need to place it back in but Im not certain if it is the differential fluid or transmission fluid. Im also not certain where the fill plug is so I can transfer the fluid back in. Anyone know?
Fill as normal through the transmission dipstick the differential and main unit share fluid.
