Warning light on dash
the ecu/ecm will be holding codes that need to pulled from it. Those will explain what the car thinks is wrong. others will post later on to tell you where you can get a code scanner from, i think you can rent them. With those codes it's possible to tell what part has failed.
Es10035 (01-29-17)
