Xenon to Halogen Headlight switch ????
Old 11-13-16, 10:01 PM
jgad60
jgad60's Avatar
Default Xenon to Halogen Headlight switch ????
I am trying to help my son get his 2000 ES300 back on the road. He was hit and runned last week and the front end, above the bumper was smashed. I was able to get the core support straightened out (within reason) and found a decent used hood. His had the deluxe xenon, self leveling headlights which were smashed beyond any chance of salvage. Replacement units are very expensive. He found a pair of the standard halogen lights at a local pick & pull wrecking yard. Does anyone know if I can simply swap them out and install the standard lights with the existing wire harness? If the plugs are different can I splice in the different plugs? Thanks, Joe
Old 11-14-16, 12:50 AM
xoarz
xoarz's Avatar
Yes you can use the halogen housing. however you cannot use the D2R HID bulbs, you need to get an H7 bulb.
Old 11-21-16, 10:07 PM
jgad60
jgad60's Avatar
Thanks for the help. I cut the leads out of the shattered unit and spliced the wires that went to the ballast onto an H-7 bulb socket. Worked great.
JasonJett
11-28-16 01:54 PM
dvdchance
03-19-14 11:10 AM
ApokC
10-17-10 09:32 PM
ghd8989
07-23-07 11:47 AM
newbieee
Lighting
11-09-05 11:44 AM
Quick Reply: Xenon to Halogen Headlight switch ????
