98 es300 wiper screeching
Old 09-02-16, 06:39 PM
80es300
80es300's Avatar
Default 98 es300 wiper screeching
Folks,
Anyone else experiencing this annoying screeching noise from windshield wipers, especially when the rain is not heavy? It has been going on for sometime. Tried changing the wipers and it would be quiet for few weeks but then comes back. So I think something else is going on. On the RX forum, someone talked about lubricating the bushing around the shaft that the wiper arm rotates around (He had to yank off the big plastic piece that covers the assembly at the base of the passenger wiper arm and then put some oil around the shaft bushing)
Anyone dealt with this on ES, any tips
Thanks
Old 09-10-16, 07:58 AM
80es300
80es300's Avatar
No one has this kind of issue, am I the only lucky one
Old 09-10-16, 01:17 PM
Received 2,707 Likes on 2,292 Posts
I've had good luck with OEM refills, or you could replace the whole blade depending on the condition.
Old 09-10-16, 03:45 PM
PFB
PFB's Avatar
If you already changed the wipers, than the next most common cause is a dirty window.
Clean it well using something like Windex together with Mr. Clean magic eraser. Use the magic eraser first.
Old 09-13-16, 03:26 PM
tomf
tomf's Avatar
Try cleaning your wiper blades with denatured alcohol. Or better yet buy these https://www.amazon.com/gp/product/B0002Z9QWQ/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 . (PIAA Silicone wipers. They are fantastic.) 22 inch for drivers. 18 inch for passenger.
Old 09-14-16, 08:34 AM
BDSL
BDSL's Avatar
You have to isolate where the noise is coming from. Is it from the wiper blades? Or from the motor? Or from the axis/bushing where the arms are rotating at?
My previous and current Lexus ES don't have this issue.
Old 09-14-16, 03:18 PM
01ESgray
01ESgray's Avatar
tomf is right. Dentures alcohol will cure speaking/ dirty wipers. I went cheap at Walmart for a dollar I purchased 90% isopropyl alcohol from the pharmacy area and they are supple and quiet. I perform this routinely now in my maintenance schedule.
Old 09-14-16, 08:28 PM
80es300
80es300's Avatar
I see that the wipers screech only in one direction (when coming back)... not sure if that gives any hint.
I will try cleaning the wipers with alcohol wipes and will also clean the winshield with mr clean eraser and see if that helps.
Thanks all for your inputs
Old 09-14-16, 09:54 PM
crwys
crwys's Avatar
If you end up replacing your wipers I recommend these:
https://www.amazon.com/gp/product/B007TG7I0I/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I have had them since Feburary 2014 and they are still working well. They were making a small squeaky noise about 5 months ago, i just wiped the rubber part down on the wiper blades and they were good to go.
Edit:
Didn't see the post above me recommending other wiper blades. If you are looking for cheaper alternative then use the ones I posted.
Old 09-15-16, 08:35 AM
WILLYumD
WILLYumD's Avatar
Edit:
The link you posted doesn't work, but
this this
one does. It comes up as Bosch Clear Advantage $10 for the 22 and $9 for the 18.
I currently use Rain-X Latitude and they work BEAUTIFULLY, have been for a little more than half a year.
Old 09-15-16, 09:07 AM
crwys
crwys's Avatar
The link does work you just need to copy and paste the url. Hyperlink isnt working on club Lexus on my mobile for some reason but it worked on my desktop.
Edit. Your link isn't working by the way lol.
Old 09-15-16, 09:52 AM
WILLYumD
WILLYumD's Avatar
Thanks haha
I had to open the hyperlink menu and then click ok the : in the link didn't go through the first time (?_?).
Old 09-15-16, 11:55 AM
mmatheny
mmatheny's Avatar
DO NOT USE DENATURED ALCOHOL!! It will dry out the rubber and make them brittle. Just using a water soaked rag to take off all the grunge on them will make them work almost like new. When I was younger, you could get a device you ran along the blade edge to take off the grunge and square off the blade edge - the blade edge needs to be square to wipe clean. I can't find anything like it, probably killed off by the blade manufacturers!! When it gets rounded, time for new blades.
Lexterious
11-24-21 04:05 PM
diverchris
02-21-11 06:28 AM
Papajorgio
SC- 1st Gen (1992-2000)
09-07-09 09:38 AM
happy_es3
01-20-08 08:38 PM
medialexus
01-26-05 06:33 PM
Quick Reply: 98 es300 wiper screeching
