While the intake manifold is off what sensors should I replace while im in there?
The harness for the knock sensors, and the coolant bypass hose.
Since the plenum has to come off, its a good time to check the rear valve cover gasket for leaks, and change the PCV valve and spark plugs.
I have knock sensors, the harness, spark plugs and will prob get the hose. On my Avalon I remember a few years ago they replaced a sensor under there that I thought had something to do with the coolant? I mentioned to do the sparks while they were in there but cant recall the sensor? Thanks!
