Strongly considering purchasing 2003 es300...
http://www.championshipmotors.com/ve...1d2789967c760/
I recently rear-ended another car with my 98 corolla. The parts and labor to fix it would be almost 800 and that is not worth it to me. I knew my next car was going to be either a lexus, acura or infiniti. ES 300 seems like the best choice for me. This one is very clean and I liked it when I drove it. My dad thinks its a stupid decision to buy a car with 140k miles on it for 6000 but it seems like a good deal to me.
What do you guys think? Anything else I should look for before I close the deal?
Always hard to tell from internet photos, but exterior looks really nice. Bit of wear on the interior, but not terrible. Usually a good idea to have an independent mechanic do a pre-purchase inspection. Find a place familiar with Lexus/Toyota or at least someone that is a master tech. 6000 sounds like a decent price for dealer.
You're in my general area, haha. I have an 03 ES300 and I absolutely love it. If only Redmond wasn't so far away from Burien. I'd give you a good deal on a buyers inspection. I'll check Toyota's NSH database and see what type of services have been done for the car. Just PM me.
I went into Lexus and pulled the service history reported by the Lexus dealership.
Two things I did not see were the timing belt/ water pump change (85K recommenced replacement.) and spark plug change (120K recommended replacement). If you want to inquire if those have been changed.
Also I did not see any drain and fill for transmission fluid. (more preventive maintenance and easy to do.
Service History for VIN: JTHBF30G630136884
Sort By:
Service Type Date Service Provider Mileage Repair # Description
Dealer Reported 10/19/2007 Lexus of Seattle, LLC 51859 0068557 MISC PLEASE PROGRAM VALET KEY (SEE PARTS) - MILES OUT=51858 - PROGRAM OF VALET KEY COMPLETED IAW LEXUS PROCEDURE.
Dealer Reported 10/19/2007 Lexus of Seattle, LLC 51859 0068557 1,000 MILE SERVICE SET LEXUS PERSONALIZED SETTINGS USING WORKSHEET FILLED OUT BY CUSTOMER - FOR CUSTOMER CONVENIENCE - COMPLETED LEXUS PERSONALIZED SETTING IAW LEXUS PROCEDURE. .40 LABOR. MILES OUT=51858
Dealer Reported 10/19/2007 Lexus of Seattle, LLC 51859 0068557 MISC 1 NO WASH OR VAC. - . - NO WASH OR VAC.
Dealer Reported 06/22/2006 Prestige Lexus 41555 0287187 OTHER INSPECTION COMPLIMENTARY CAR WASH - ============================= ======== - ============================= =======
Dealer Reported 06/22/2006 Prestige Lexus 41555 0287187 ES300 A 30K SERVICE IS RECOMMENDED - CUST. DECLINES, AT THIS TIME - TECHNICIAN INVESTIGATED, AND CONFIRMED THAT A 30K SERVICE IS RECOMMENDED, INCLUDING REPLACING THE COOLANT, BRAKE, TRANS, AND DIFF. FLUIDS, ECT. AS STATED ABOVE, CUST. DECLINED, AT - THIS TIME
Dealer Reported 06/22/2006 Prestige Lexus 41555 0287187 NON WARRANTABLE OPERATION CODE PART IS IN - INSTALL S.O.P. - CENTER CONSOL - HOOK IS BROKEN - WARRANTY - REMOVED CENTER CONSOL AND INSTALL TOP - REPLACE CENTER CONSOL TOP
Dealer Reported 06/04/2003 Lexus of Tacoma at Fife 2330 0064012 CUSTOMER STATES; VEHICLE PULLS TO THE LEFT WHILE DRIVING COMPLIANT VERIFIED, SET TIRE PRESSURES, PERFORMED - 4 WAY ALIGNMENT - ROAD TESTED - OK NOW. ** WARRANTY OPCODE **
Dealer Reported 05/07/2003 Lexus of Tacoma at Fife 1550 0062976
Dealer Reported 05/07/2003 Lexus of Tacoma at Fife 1550 0062976 __ SET ALL TIRES TO 32 PSI FRONT TIRE DEPTH 10 /32 REAR TIRE DEPTH 10 /32 __ INSPECT AND TOP OFF ALL ENGINE COMPARTMENT FLUIDS __ CHECK FUNCTION OF ALL SYSTEMS ON VEHICLE __ FINAL VEHICLE ROAD TEST __ COURTESY HAND WASH & VACUUM
Dealer Reported 03/31/2003 Lexus of Bellevue 2 0178651
Sort By:
Sort By:
Sort By:
The water pump and timing belt are usually done together around 90k and are more difficult to do your self. And more pricey parts/labor wise
copy252
05-14-06 04:06 PM
