IS250/350 rims on 02-06 ES300/330
Hello folks,
Just curious if 17" IS250/350 rims fit 02-06 body style ES300/330s?
Rims in question are 17x8, et45.
if they fit, what tire size would be recommended for the es?
Thanks in advance
Thanks in advance
The stock ES330 wheel is 17x7" with a 50mm offset and 215/55/17 tires.
Using the wheel offset calculator, you'll have 8mm less clearance from the rear wheel to the strut. You'll want to double check you have enough clearance with those stock wheels before mounting the IS350's rims on, otherwise you'll need a 5mm spacer.
http://www.1010tires.com/Tools/Wheel-Offset-Calculator#
IamLexus
07-11-11 02:59 AM
