2000 Lexus ES300 P0171 no O2 sensor voltage?
car was showing dtc P0171.
The main thing I need to know is why the O2 sensors are not ready and they are not reading any voltage. I tested the voltage at the connector and they are fine. Its like the computer can't see the O2 senesor Also the fuel trim is at 99.2% on the post cat sensor. WTF What is going on with this car????
It drives fine too.
car has 140,000 miles and needed regular maintenance items.
Replaced:
-fuel filter
-valve cover gaskets/spark plugs/upper intake manifold gasket
-thermostat(was stuck open)
-cleaned MAF sensor(measuring proper amount)
-replaced sticky PCV valve
-checked and no vacume leaks.
Drive status since DTC clear
misfire: complete
fuel system: complete
components: complete
catalyst: incomplete
evaporative: incomplete
O2 sensor: incomplete
O2 sensor heater: complete
O2 sensor Bank1 sens1 0volts just replaced
O2 sensor Bank1 sens2 .9volts
O2 sensor Bank2 sens1 0volts just replaced
fuel trim data
F/T Bank1 sens2 99.2%
F/T Bank1 sens1 Nothing showing up
F/T Bank2 sens1 Nothing showing up
Basically nothing is changing after i replaced these things. I was really thinking the O2 sensors were bad beacuase they where not reading any voltage with a scanner. I am scanning with torque connected to elm327 Bluetooth.
It drives fine too.
Replaced:
-fuel filter
misfire: complete
fuel trim data
I will answer my own question after doing some research. This model uses air to fuel ratio sensors. So they cannot be seen with a scan tool that looks for typical O2 sensors. I was using the Torque App on my phone with a bluetooth adapter. This works fine for other cars, but not the Lexus.
Barnabas
11-13-17 12:31 PM
SlowRider1
18
03-29-16 02:53 PM
techiedude
05-02-12 06:57 PM
