93 es300 dog bone mount
Old 11-14-15, 06:17 PM
hoopes999
hoopes999's Avatar
Default 93 es300 dog bone mount
anyone know how much play these dog bone mounts should have. I have an obvious mount problem because I have a tone of engine movement and hard 1-2 shifts, clunking ect. I had my front mount replaced and nothing changed, I replaced the dog bone about a week ago with a cheap one (westar) and it literally cracked with in one day! so I put my old one back on. I do see cracks around the rim of it so i'm pretty sure it needs to be replaced as well. I dont think there is anyway around not going OEM with this part. I could only see one side of the rear bushing due to the location it is ( you should see where they stuck this Fing thing) and it looked fine but its still suspect. What I'm asking is can a dog bone mount cause harsh shifting and banging clunking. When I watch it as someone else is reving and shifting into drive , rev , ect, it does have a decent amount of movement. thank you
Old 11-14-15, 08:25 PM
JetsonES
JetsonES's Avatar
You could always do the 3m windshield sealant trick to fill in the voids in the mount. Might increase nvh a little bit but that sucker won't move after that.
Old 11-15-15, 07:40 AM
hoopes999
hoopes999's Avatar
lol, hell yeah I'm gonna try it, Will let you know how it works..thank you. What is the name of the product ? Just 3m Windshield repair?
Old 11-15-15, 08:23 AM
JetsonES
JetsonES's Avatar
3m window weld
http://importnut.net/motormount.htm
Please follow up, I'm interested to see how it impacts nvh.
Old 11-15-15, 08:27 AM
tradosauru
tradosauru's Avatar
Originally Posted by JetsonES
3m window weld
I used the window weld treatment on an engine motor mount that is notoriously known to fail on the Ford Freestyle. After 3 years it is still working great. I believe it is about $20 for a tube.
Old 11-15-15, 08:33 AM
JetsonES
JetsonES's Avatar
Did it make any difference in vibration or harshness?
Old 11-15-15, 08:48 AM
tradosauru
tradosauru's Avatar
No. But it is a concern. I'm not sure I would fill in all the motor mounts with Window Weld. lol
Old 11-15-15, 09:07 AM
JetsonES
JetsonES's Avatar
Yes, just poorly designed ones. I did full urethane mounts in my old mr2 turbo and it mast definitely raised the nvh factor, not that I cared because I knew what I was getting into and you don't expect comfort from a car like that. Damn it I miss that car!
Old 11-16-15, 11:43 AM
hoopes999
hoopes999's Avatar
Do you guys know what mount is usually responsible for causing a hard 1-2 shift and clunking on downshifts
Old 11-18-15, 08:47 AM
surgeon0
surgeon0's Avatar
Front (hydraulic) and Rear (rubber insulator). You can also test this by holding the brake, put into gear, and raise. Notice front move more in D and rear more in R. Of course dogbone (torque mount) gets weak over time.
Those are the two primary mounts. Others are secondary.
FwC
03-11-18 12:59 AM
new_berlin
07-14-13 04:26 PM
RXGS
11-18-11 05:47 PM
Rtstrider
08-29-07 11:21 PM
Quick Reply: 93 es300 dog bone mount
