Timing Belt Lesson Learned
Old 10-11-15, 05:35 PM
ggroneman
ggroneman's Avatar
Default Timing Belt Lesson Learned
Decided to give my 1999 ES300 with 103k mi to my daughter and bought a Jaguar ... yeah i know. Although I have never read where the timing belt broke, I decided I would go ahead and replace Timing Belt and Water Pump since my daughter has pretty bad car karma. Talked to a guy at Lexus and he advised that they usually just replace belt and pump ... so i opted NOT to get a full kit from Rock Auto.
Changed the belt and pump in about 6.5 hours, fired it up and all seemed good. Test drove it to the parts store for some engine cleaner, posted on FB how profeciently I changed the belt/pump, got back in car and on the way home BAM! CEL and TRAC OFF light up. Back to parts store to gety codes ... P1346 & P1351 ... VVT Right and Left. Back home and after tearing it all back down I find the belt has slipped several teeth on both cam pulleys.
Here is the lesson learned ... if you are going to replace the timing belt and water pump (and i assume you know to do both) ... ALWAYS REPLACE THE TIMING BELT TENSIONER!
Replace tensioner and all is good.
Just buy the full kit, a lot cheaper than an extra 6 hours of my time.
ps. The original timing belt looked virtually brand new.
Old 10-11-15, 06:11 PM
JetsonES
JetsonES's Avatar
This is true with any labor intensive job, don't succumb to the temptation of cutting corners. It's a hard lesson to learn but it lasts, trust me, I've been there too.
Old 10-11-15, 07:22 PM
BDSL
BDSL's Avatar
And make sure there is no grease / oil on the belt and the sprockets / gears.
Old 10-12-15, 07:08 PM
speedkar9
speedkar9's Avatar
So you compressed the old tensioner and put in the key to reset it?
If you're going to cheap out on a TB job, sure, skip the water pump and idlers, but not the hydraulic tensioner.
Old 10-13-15, 02:59 PM
artbuc
artbuc's Avatar
I have done 4 TB jobs on 1MZFE engines and never replaced the hydraulic tensioner. If it is not leaking oil it is good to go. Definitely replace the idler bearings (OEM only) and WP only if the bearing is rough or it is the second TB change (Aisin only).
Old 11-02-15, 08:49 AM
mmatheny
mmatheny's Avatar
No bent valves?? LUCKY!!
Old 11-03-15, 02:58 PM
OceanView
OceanView's Avatar
not on a 99.
From 2000 on he would have been in big trouble.
Old 11-05-15, 09:37 AM
jaredmac11
jaredmac11's Avatar
I can't believe they advised you against getting the kit with tensioner! That's crazy. The labor alone is worth spending the time for the full kit.
Man, my faith in a shops opinion is nil.
That sucks!
Nathan1
05-22-20 04:08 PM
430keeper
10-16-14 11:42 AM
swat1727
12-11-08 12:44 PM
BA_GS400
Performance
12
09-07-06 06:21 PM
damon
Maintenance
05-17-05 07:38 AM
Quick Reply: Timing Belt Lesson Learned
