Cost of Replacing Timing Belt
+1 on the studs.
As for the crank pulley bolt, depending if it was loosen before or not, I was able to crack it loose with a long breaker bar and blipping the starter. However, when doing it first time on my 06 ES330 which never had its timing belt changed before, blipping the starter didn't work. I had to get an impact gun to break the bolt loose.
Safetybob, I highly recommend pulling the engine cover there are a lot of hoses under there that get brittle and pop off over time. I am slowly replacing mine one at a time, car is at 135k. I also like to zip tie the ends, not really a necessity unless your car is boosted but cheap insurance in my eyes.
I was able to remove the water-pump from my 3MZ-FE ES330 and my 1MZ-FE Solara without touching the studs. You just have to unbolt timing belt cover #3 and slide it out of the way.
Here's the timing belt procedure:
As long as you're able to knock the crank pulley loose, the rest can be done very easily with hand tools. The 3MZ differs slightly with the tensioner bolting in from the side, making you have to unbolt and swing the little power steering bracket out of the way to remove.
Spark plugs on the other hand require the removal of the intake plenum, and don't have to be changed with the timing belt. Its not hard, the trickiest part is that 14mm bolt right in front of the firewall:
Speedkar9, thank you for the timing belt video and most importantly, the difference that the ES330 motor has. Sorry I don't know my cars exact motor series. In some aspects, this looks a lot easier than my 4 banger Hondas I normally have to do (and dread), but nice to see that they didn't make it that easy with that seal towards the back of the engine compartment. I also liked your method of marking the belt. With Honda's we have marks and dots all over the camshaft so you don't mess up, but it does take awhile to get them all arranged, your method would have saved me hours the first time I did one of my accords with the counter rotating balance shafts.......
Two questions though: Where did you get that camshaft holder device and did the pin you took out of the tensioner......did that come in the kit from Rock Auto?
Bob
Bob
Bob
Bob
The camshaft holding tool I got from Princess Auto (Canadian equivalent of Harbour Freight) and the pin comes in the tensioner from RockAuto.
There was a recall on the 05/ES330 to re-install the crank pulley. See if you car qualifies.
If so, you could have the timing belt replaced at the same time. I did this and saved a couple of hundred bucks.
I took my car in a few years ago and they said I didn't need a new harmonic balancer.
Thanks
I would use a torque wrench, they can be had cheaply at harbor freight and I had a friend in metrology test it, he said it was pretty much on point for accuracy. The key is to unload the spring when you store it to preserve the accuracy.
My torque question was for speedkar9, as I saw in his video how he just rattled the bolt on with his impact gun and called it good. I would not just do this, I have a good friend that did this on the 3.4L V6 in his T100, and a couple of days later the bolt fell out on the highway, the balancer fell off, took out a bunch of other parts (fan, shroud, all the engine belts) and damaged the end of the crank. It left him stranded on the highway in the middle of the night.
You really need a tool to hold the balancer after you reinstall it, then use a proper torque wrench to set it tight.
