Cold water dripping under 02 es300 car towards middle
Old 09-03-15, 06:15 PM
new_berlin
new_berlin's Avatar
Default Cold water dripping under 02 es300 car towards middle
Cold water's dripping (fast) under my es300 centerish. The water is quite cold to the touch. Normally I would ascribe this to humidity (which it definietly is today) and the a/c but the location of the drip (it's nowhere near the radiator) has me wondering. Is this normal? My location is usually dry with only occasional spikes in humidity, so I am not sure about normal behavior.
Thanks.
Old 09-03-15, 06:29 PM
Received 2,702 Likes on 2,287 Posts
The A/C drain is no where near the radiator it is on the passenger side footwell. And if it is water then it has to be from the evaporator no other part of the car has/uses pure water.
Old 09-03-15, 06:41 PM
new_berlin
new_berlin's Avatar
Sounds worrisome. It's closer to the middle/center than passenger footwell (which I assume i would be close to the front-wheel-axle). Guess I'll have to crawl under to get a picture. Aargh.
Thanks for responding.
Old 09-03-15, 08:38 PM
808mcv20l
808mcv20l's Avatar
didn't someone post about a gum wrapped getting stuck into the AC drain hose causing the water to go into the center console frying electronics?
try look for that thread and check it out before something gets shorted.
Old 09-03-15, 08:40 PM
808mcv20l
808mcv20l's Avatar
found it, https://www.clublexus.com/forums/es-...et-thread.html
guess no one looks past page 1 anymore :P
Old 09-04-15, 07:16 AM
HomerJay
HomerJay's Avatar
If I understand correctly the water is dripping outside under your car? If that is correct do not be concerned, especially when humidity levels spike.
Old 09-04-15, 09:38 AM
new_berlin
new_berlin's Avatar
Thanks, I checked it out but in my case I wasn't sure what this leak is. Inside of my car is fine.
You and Lexus2000 are hopefully correct in that this is just water from the evaporator/ac-drain. I checked this morning and sure water was dripping exactly from where Lexus2000 indicated the a/c drain should be. However, the water today is NOT cold, just at room temperature. Yesterday, the water was COLD (as in from refrigerator) to the touch. Perhaps my recollection from yesterday about the location (I thought it was near middle of the car) is wrong but what would explain the temperature difference? Btw, today the humidity isn't high.
Thanks again, all.
Old 09-04-15, 11:27 AM
mmatheny
mmatheny's Avatar
The water could be dripping on something and then traveling toward the center of the car before dropping.
Old 09-04-15, 01:52 PM
ES300NZ
ES300NZ's Avatar
it's AC, that's where my drops it.
razor10000
07-24-14 06:58 PM
emacsp
02-17-10 01:37 PM
shilla
05-03-08 03:51 AM
lmtran4
07-21-06 11:27 AM
Quick Reply: Cold water dripping under 02 es300 car towards middle
