03 es300
Old 08-03-15, 09:08 PM
Jig804
Jig804's Avatar
Default 03 es300
Have a 03 es and car stalls out when put in drive don't kno what it is one person said oxygen sensor and another person said vaccume leak need help anybody kno I will really appreciate it
Old 08-03-15, 09:12 PM
DRACO A5OG
DRACO A5OG's Avatar
Welcome Aboard Jig804,
Okay, where is the idle in park? Remember count backwards 1000,800,600 so on, there is no Zero. Zero if off :-)
Slowly check all vacuum lines. It should have thrown a CEL. Did it?
Jim
Old 08-03-15, 09:38 PM
Jig804
Jig804's Avatar
In between 600 and 700 and when in drive drops to 0
Old 08-03-15, 09:49 PM
DRACO A5OG
DRACO A5OG's Avatar
Okay, if automatic, it should be 750 RPM steady and should not fluctuate by 100 RPMs. If manual it is 700 RPM steady idle.
Let's do a test. While on, press the gas to bring the RPMS upto 800 then drop into gear. Put left foot on the brakes and parking brake on. Check if it will stall.
So did it throw the Check Engine Light?
Old 08-03-15, 09:55 PM
Jig804
Jig804's Avatar
Yep check engine light is on and it doesn't stall when pushing gas but when I push down on brakes to stop it goes to stall
Old 08-03-15, 09:57 PM
DRACO A5OG
DRACO A5OG's Avatar
Most likely you have a vacuum leak or a sensor is disconnected/failed.
Was there recent work done.
If you can borrow an OBDII reader. It can point you in the right direction.
In a pinch you can go on Craigslist and locate a rental for real cheap.
If you can, post a video of your engine compartment, concentrating on the vacuum lines. Make oil cap is tight and PCV is connected.
Old 08-03-15, 10:01 PM
Jig804
Jig804's Avatar
Yea had starter put on and I put on computer at auto zone and da print out says low bank 2 oxygen sensor and vaccum leak
Old 08-03-15, 10:08 PM
DRACO A5OG
DRACO A5OG's Avatar
Lucky, Bank 2 is you front O2 sensor. You can see soon as you open the lid. Check the connector and reconnect if needed making sure wire and housing is not touching the manifold or it will melt ( This is not the cause of your stalling )
"had starter put on" so you let a monkey wrench put it on? Okay, check around the starter, near the air filter box, I bet one or more lines were pulled off by accident or carelessness.
Old 08-03-15, 10:14 PM
Jig804
Jig804's Avatar
Will check in mourning got dark out where I'm at but I will let u kno but what does the oxygen sensor do
Old 08-03-15, 10:21 PM
DRACO A5OG
DRACO A5OG's Avatar
O2S includes but not limited to regulating your AIR FUEL mixture to make it run at it's most optimal state to save fuel and keep fuel from being dumped into the exhaust system, especially at idle. If you do not address this you will either run too rich or too lean, not good for your catalyst or valves.
Your stall issue is one or more disconnected lines. You may hear a hiss if you are lucky.
Get some rest and tackle it in the morning.
Old 08-03-15, 10:54 PM
ES300NZ
ES300NZ's Avatar
nice work DRACO A5OG really good help there.
Old 08-04-15, 12:43 PM
PFB
PFB's Avatar
Just curious. Does it do the same thing when you put it in Reverse instead of in Drive?
Old 08-05-15, 10:39 AM
DRACO A5OG
DRACO A5OG's Avatar
Any updates?
tommy329
05-23-16 04:54 AM
Alghawi
06-01-15 09:32 PM
CrusherCur
01-19-09 05:02 PM
PBLexusES
06-08-07 10:30 AM
triplecore
06-21-06 04:47 PM
Quick Reply: 03 es300
