00 ES300 Front Sway bar size? 18mm or 19mm?
Old 07-18-15, 08:49 PM
808mcv20l
808mcv20l's Avatar
Default 00 ES300 Front Sway bar size? 18mm or 19mm?
I've got a 2000 ES300 Platinum, looking to replace these swaybar bushings with Moog, unless people suggest a different brand?
I've used Energy suspension bushings in my family's 98 and 99 Camrys.
On Moog's site I'm seeing two sizes, 18mm and 19mm, I used the 18mm on the 99 Camry but unsure about the ES300.
Should I go with the 18mm bushing or 19mm bushing?
Thanks in advance!
Old 05-15-18, 07:06 AM
beamerrx7
beamerrx7's Avatar
I am needing to figure this out. Does anyone have the answer?
Old 05-18-18, 01:10 PM
ES300TX
ES300TX's Avatar
Thanks in advance!
I don't know if I can help you out, but 18-19mm sounds too thin for a front sway bar. That sounds more like a RSB. I would expect a FSB to be 22-24 mm on these cars. Probably 22 or 23. A millimeter may not sound like much, but small changes have a great impact on the car's rigidity. I wish I had a replacement sway bar for mine as the front end likes to wash out when cornering.
Old 05-25-18, 09:38 PM
Power6
Power6's Avatar
You may need to measure. Mine was 17mm, measured directly myself on my 2001 ES
To the poster above it may seem there are typical sway bar sizes, but that is just particular to your experience. The actual stifness of the bar is determined not just by diameter but also the shape and the motion ratio of the attachment point to the suspension. The ES has a direct acting sway bar that links to the strut body. Because of that the sway bar can be smaller and lighter for the same stiffness. The 17mm or 18mm bar on this car can be the same stifness of a 24mm bar on another car. Size of a bar is only comparable between the same shape and design bar on the same car.
Andreius (10-17-23)
MackGoose
04-14-19 04:35 AM
acarapella
12-12-17 12:27 PM
cha41ppy
06-01-10 12:25 PM
Quick Reply: 00 ES300 Front Sway bar size? 18mm or 19mm?
