--Can this Key blade be repaired?
Old 06-11-15, 10:00 AM
Alexbenz
Alexbenz's Avatar
Default --Can this Key blade be repaired?
key fell and broke yesterday, my backup spare turn's the car on and doors but not the trunk for whatever reason...
Old 06-11-15, 01:19 PM
Megafast13
Megafast13's Avatar
Yeah should be able to use some super glue or JB weld for it
Old 06-11-15, 03:44 PM
samsonn25
samsonn25's Avatar
Your backup key is a valet key that turns the ignition and opens doors. But not the glove box or trunk, to deter thieves.
Old 06-11-15, 07:10 PM
VicSWFL
VicSWFL's Avatar
Hi Alexbenz,
For the repair of the broken key, I'll add my vote to JB Weld. With this broken key as your only master key, you may wan't to get a backup master key so you won't be at the mercy of the dealer if this key gets lost or permanently damaged.
Vic
Fort Myers, Florida
2003 ES300 Millenium Silver
Old 06-11-15, 10:59 PM
Alexbenz
Alexbenz's Avatar
can the black cap portion be removed and replaced? the piece that broke is gone...don't know where it went...
the valet key looks just like my original key. what's a low cost way to replace the key if need be?
Old 06-13-15, 03:37 AM
ES300NZ
ES300NZ's Avatar
the key blade is "made into" the black housing, so no.
Old 06-14-15, 02:16 AM
Alexbenz
Alexbenz's Avatar
What's another cheap way to make a new key that looks like OEM but minus the OEM price tag?
Old 06-14-15, 12:38 PM
VicSWFL
VicSWFL's Avatar
Default Reasonably priced keys
Hi Alexbenz,
Earlier this year I acquired my 2003 ES300 and received the three button remote key and a valet key. I purchased a new master key without the remote feature, cut from a picture of my master key, for $24.89 delivered from an Ebay seller called 1010keys. Their email address is Ten10keys@aol.com
I also purchased the "flat key" wallet size emergency master key from them for $34.98 (see attached photo). They sent programming instructions and it was easy.
Hope this helps,
Vic
Fort Myers, Florida
Old 06-14-15, 02:17 PM
antonios32
antonios32's Avatar
Super gluing is technically a good and bad idea. If you keep a lot of keys on your Lexus key, Super glue is NOT a good idea
Old 06-14-15, 02:31 PM
HomerJay
HomerJay's Avatar
I don't know if I understand -is your problem simply the broken piece or is the remote is not working? If it's the former maybe one of those car key covers or similar may help. http://www.high-end-motorsports.com/...te-covers.html
Old 06-15-15, 10:49 AM
Alexbenz
Alexbenz's Avatar
Originally Posted by VicSWFL
Hi Alexbenz,
Hope this helps,
Vic
Fort Myers, Florida
i actually have one of those keys somewhere...i have a total of 4 keys...2 masters with remote, a valet key that looks like a master and the thin one you posted...
i can't glue anything because i don't have the piece that broke.
it's the broken piece. Can't have it on the keyring anymore....i have a 97 and haven't seen anything for it online
Old 06-15-15, 11:18 AM
afang
afang's Avatar
I had a similar problem. Shape a piece of wire to cover the gap and epoxy it to the key. Then get a key cover from Toyota. Mine has been holding up for over a year.
Old 06-15-15, 01:06 PM
Received 2,707 Likes on 2,292 Posts
Get a blank key 90999-00220 and have it cut. It will need to be programmed which is really easy.
Old 06-16-15, 01:44 AM
Alexbenz
Alexbenz's Avatar
How much we talking? And why would it need to be programmed? Does it have a transponder?
Old 06-16-15, 08:40 AM
I don't know if if has a transponder, maybe not. Just Google the part number.
Quick Reply: --Can this Key blade be repaired?
