Will these rims fit an ES?
Old 04-19-15, 04:42 PM
EPayne42
EPayne42's Avatar
Default Will these rims fit an ES?
Hello ...I own a 1999 ES300. Will 2001-2004 17" IS300 rims fit?
Old 04-19-15, 10:53 PM
Chocolate
Chocolate's Avatar
Yes.
The bolt pattern is 5x114.3 aka 5x4.5.
The hub bore is 60.1mm. I have RSX 16" 5 spoke wheels on my 04 Lexus, I use a 60.1 to 64.1 hubcentric ring with them for a tight fit on the hub. With these hubcentric rings you will be able to use most Honda/Acura OEM car wheels.
Old 04-19-15, 10:56 PM
Chocolate
Chocolate's Avatar
I can say though that I paid for new 18" wheels and tires before selling them in favor of lightweight aluminum 16s. Ride and acceleration decrease, in return for a slight increase in roadholding, with bigger, wider, and heavier wheels.
Old 04-19-15, 11:46 PM
Chocolate
Chocolate's Avatar
It took me a while, but I learned the true goodness of fat tires. Superior tolerance to abuse, a higher load index, and lower weight, to say nothing of cost.
Old 04-21-15, 06:51 PM
EPayne42
EPayne42's Avatar
Thanks for the help on this one. I will keep my old 15's just in case the new rims cause trouble. The new rims will definitely be an upgrade in styling. The old OEM rims look dated to say the least. I found Michelin Primacy MXV4's for $145ea. Not too bad.
Old 04-21-15, 07:35 PM
speedkar9
speedkar9's Avatar
The IS300 rims will fit. I had them on my Solara (same suspension setup as the ES), but there are two issues: they're heavy and the rear tires might rub the struts.
The rubbing depends on the tire you use (215-50-17, same as stock diameter) rubs just barely and a 3mm spacer is enough to move the tire away from the strut.
They're good looking rims, but I've sold mine and got am now running a set of Gen 2 Solara rims, so consider other Toyota/ Lexus OEM rims if shopping around for a used set. They all have the same bore, offset and bolt pattern and will bolt up.
The Michelin tires are a good way to go, but if you want to save a little money the Pirelli P7's are a close second, albeit not as quiet as the Michelins.
Old 04-22-15, 03:38 PM
Chocolate
Chocolate's Avatar
For 17s, I would also consider the 17" 05-06 RSX Type S wheels. Good looking wheel, made by Enkei, and very light.
tony808
04-29-14 10:57 PM
neonwombat
10-29-13 03:54 PM
sintox
11-06-08 06:48 AM
xfactor70
04-06-08 10:49 PM
Quick Reply: Will these rims fit an ES?
