DIY: Rear Strut Replacement
Thanks for the feedback. Are you talking about the upper spring seat? I think its rubber.
I didn't take my strut assembly apart to know for sure.
If you want the stock Lexus smooth ride, you'll have to fork out for OEM struts. If you want something durable, but stiffer, go with KYB. If you want a soft ride but don't mind swapping struts every few years, go with Monroe. If your doing it for the sake of selling the car, I'm sure Camry quick struts will bolt up fine.
Have you tried a Toyota dealer? Usually they can be cheaper. If you cross reference the part number, I believe the strut is the same as the V6 Camry.
Rock auto four KYB's $308 out the door
Is there a particular reason for replacing all four at once? If is it just the rear of the car sagging and bouncing, start replacing the rears first and save the fronts for when it wears down a bit more.
I presume you plan on keeping your ES for a very long time and really would appreciate that smooth Lexus ride, then it would make sense to get OEM struts over the KYB.
The back is starting to sag and is bouncy.
The left front is starting to weep fluid
I ordered the KYB's today. Will install next weekend. It is a gamble on the ride stiffness / we shall see..... I will post my comments after they wear in a little
I went OEM rubbers and mounts
The KYB's will mellow some but you will never get to the point of having the Lexus like ride.
Hello All
Has anyone used the aftermarket strut mounts (i.e., KYB strut mounts, part SM5175) when replacing the rear struts? I have a 2000 ES300 and will replace struts and springs to tighten up the rear suspension. For the front, it was recommended that I use OEM strut mounts, which are considerably more expensive than the aftermarket. But for the rear, should I go Toyota parts or aftermarket for the mounts?
KYB mounts are about $$40 each. The online OEM part price is $142 each. So, there's a huge difference.
Thanks for any tips on this.
Pat
Pat
Generally the rear upper mounts are in good condition and can be reused. Any noises from the rear struts?
PatGalvin (12-31-18)
The rear suspension noise is primarily related to when I go over speed bumps or hit the dip at the bottom of my driveway. It is more of a dull squishy sound. Not a real thump or rattle. But, I'd like for it to be quiet.
I would like to lose this squishy sound and would like to tighten up the ride. I just bought this garaged "grandma" car with 70,000 miles on it and am sorting through a few of the issues. It is a California car, so no rust or under body corrosion. I could just reuse the top strut mount... Just thought it would be good to replace while I've got the struts out of the car and disassembled. I do want to install the KYBs and Moog springs and see if I can stiffen up the rear suspension a bit.
Anything else in the rear suspension that I should be checking for wear (for a car with this mileage)? Thanks
Pat
Pat
KYB's will firm up the suspension a fair bit. The only way to guarantee the mounts are not going to give you issues is go OEM I've read mixed results from Moog, Monroe and KYB mounts.
Rear or Front Stabilizer link
The stabilizer link bolts are the only bolts I've ever had a problem with. If Lexus would have spent 30 cents more for a better bolt, life would be perfect.
