First Lexus first problem
Hi Lexus owners,
I've just owned my first Lexus, actually first car ever. And I notice that before I start the car, there's a check engine light and oil light is on. But when I start the car working and driving, there's no lights on. What this that mean? I've been reading on here about it just not sure if it's a problem to see while driving the car or before start the car. Sorry if I sound so amateur, I just have no idea about technical stuff yet.
Your car is working perfectly. ALL the warning/info lights on the dash should be illuminated when you turn the key to ON but you don't start the engine, this is a test feature to make sure all systems are working.
Like you said once I turn the key on, all lights illuminated for a second and then before I start the engine there's actually three lights keeping lighted: Battery, Oil(I believe so) and Engine light.
Previous owner said that he has just changed battery few months ago and the last time he changed the oil was 4000 miles ago. So I'm hoping it will be fixed when I change the oil.
oops I misread your post, yes that is completely normal, no worries. I would recommend you change your oil every 3,000 because of the 1MZ sludge issue to prevent that from happening.
If you say it's normal no need to worry then, I was just thinking maybe I should take car to the mechanic, I worried that those 3 lights keep on before start the engine. But like I mention there's no lights while the engine working and driving.
Sorry for goofy questions but since it's my first car I wonder what kind of oil I should use? Do you recommend specific oil better for ES300 models?
No no problem at all, that's what the forum is for. I'm not sure if you're planning on changing the oil yourself or not, but any full synthetic oil is good for this engine. I take mine to a friends shop (who I trust very much) and they give me a good deal on a synthetic oil change. It just runs a lot better than conventional oil and makes the sludge issue a lot less likely. As long as you change the oil every 3,000, you will be just fine.
Other members on the forum would know better on specific brands of synthetics if you plan to do it yourself, as I don't change mine myself. Although I have heard Amsoil is a very good synthetic that can go much longer than the usual 3,000 mile interval.
Since it's my first car , I won't do it by myself. I will take the car to the NTB-National Tire and Battery near my house. They have a deal like $19 Oil change and lots of other services including in this price. Seemed like a good deal but you guys know better. There's also expensive options like $39 high mileage synthetic blend oil and $60 full synthetic blend oil. I'm not sure which one I should choose.
Also considering that I drive this car maximum 5 miles daily and I don't think I can beat 4000 mileage after a year, so I thought I could go for expensive synthetic oil because it will cost just once a year. But would like to ask your opinions before changing the oil.
Thanks again, looks like forum will help me to learn a lot about cars.
Driving 5 miles a day can actually create a lot of sludge in your engine, because your oil will not have enough time to get to operating temperature and burn off any left over moisture. Go with regular engine oil and change it at least every 6 months. Also, take the car out on longer drives, at least once a month (20-30 mile trips).
I was so confused about oil types since it's my first car. I will do it like you advise.
