Car starts, idles, idles low, then rough, and dies.
Old 08-10-14, 10:11 PM
Bumbobee
Bumbobee's Avatar
Question Car starts, idles, idles low, then rough, and dies.
Hey guys,
Today I was coming back from a long trip to the lake (450 km) and the car was running great. I dropped someone off, then started the car back up again, it idles rough and died. I tried a few more times and same thing.
I finally held one foot on the brake, one foot giving it a little gas so it wouldn't die, and I managed to shift it into gear before it died. I made my way home, the car felt a little funny as if there was a jerkiness to acceleration. It would also idle rough in gear at stop lights but it didn't die.
There is no check engine light.
I replaced the oxygen sensors, knock sensors, a while ago, maybe 5000-6000 km ago. Car was running fine all this time.
What could it be?
Old 08-11-14, 02:22 AM
ES300NZ
ES300NZ's Avatar
gee .. that really could be alot of things.
- vaccum leak, ripped inlet pipe, etc.
- bad MAF,
- bad water temp sensor,
- poor fuel/part blockage or fuel filter obstruction,
- bad coil (s)
- bad earth, or poor earth connection
- VVTI sensor failure.
- a glitch. with the ecu, it learned something wrong and now needs a reset. (start here it's free)
Old 08-11-14, 04:55 AM
speedkar9
speedkar9's Avatar
Idle air control valve,
www.youtube.com/watch?v=i82s4ZfR2js
Old 08-11-14, 06:56 AM
Bumbobee
Bumbobee's Avatar
Will try the reset.
MAF sensor is new.
VVT sensors are new.
Will try cleaning the IAC.
Old 08-11-14, 07:21 AM
Bumbobee
Bumbobee's Avatar
Just cleaned IAC and throttle body, did not help, problem still there.
Old 08-11-14, 07:54 AM
PFB
PFB's Avatar
If you filled it up recently, could it be that you got a bad batch of fuel somewhere on your trip?
Old 08-11-14, 08:52 AM
Bumbobee
Bumbobee's Avatar
Filled it up with Shell V-Power 91 no ethanol in a Toronto gas station. First time running 91 octane in a while, and I think first time since changing all the knock sensors and oxygen sensors etc.
Old 08-11-14, 10:58 PM
Bumbobee
Bumbobee's Avatar
Brought it to the mechanic and he said it's probably the IAC valve.
He said he will try and clean it and see what happens. If not going to have to order a new one from rock auto. Here in Canada parts source wants 297 + tax for one...right...
Old 08-13-14, 09:52 AM
Bumbobee
Bumbobee's Avatar
Mechanic took out the IAC valve, cleaned it, let it soak over night. Put it back in and car works.
Thank god!
M9000
RX - 1st Gen (1999-2003)
15
10-25-21 10:03 AM
Zen470
05-30-13 02:48 PM
ALLWiTE2JZ
SC- 1st Gen (1992-2000)
14
07-09-10 12:09 PM
sc-driver
Performance & Maintenance
05-16-10 08:38 PM
Robbyh
07-22-07 04:51 PM
Quick Reply: Car starts, idles, idles low, then rough, and dies.
