1992 es300 running rich
Old 08-09-14, 09:05 PM
shild64289
shild64289's Avatar
Default 1992 es300 running rich
running rich, removed ecu found leaking cap, repaired/replaced ran great for several weeks.
new plugs, rotor, cap & adjusted timing.
started running rich again, replaced ecu, ran great couple weeks. Found #4 plug wet with gas. Cleaned #2, 4, 6 fuel injectors. Ran good for test drive of 20 miles or so. Found all plugs black indicating all cylinders are flooding. Disconnected battery for couple days, once again ran great for 20 mile test drive. When restarted running rich once again.
can anyone help?
Old 08-09-14, 11:41 PM
ES300NZ
ES300NZ's Avatar
just suggestions;
bad MAF or AFM ? (quitelikely)
bad ECU (two wire) watch temp sensor
bad warm up switch, I can't remember the correct name for this sensor, it's basically a on/off water temp switch and it tells the ecu whether the car is warm or not. (extra fuel or not). older engines have this, yours might.
Old 08-11-14, 06:59 AM
shild64289
shild64289's Avatar
Default es 300 running rich
Thanks for your reply but wouldn't MAF problem generate error code and turn on check engine light?
Old 08-25-14, 06:38 PM
shild64289
shild64289's Avatar
My 1992 Lexus ES300 intermitten skips like loss of ignition or fuel and check engine light comes on resulting in codes 32, 42, and 43. Clearing codes may run great for 30-40 miles before it does same thing again.
Can I get some help/suggestions on what might be happening?
Old 08-25-14, 07:19 PM
ES300NZ
ES300NZ's Avatar
what about the o2's ? have you thought about replacing those, even with second hand low km's one ?
supersc30
Performance & Maintenance
02-12-17 12:11 PM
wnyjazz
10-12-15 02:27 PM
SC300_704
22
07-05-11 09:38 PM
Meanshyguy
02-09-11 08:34 PM
Track5tar
SC- 1st Gen (1992-2000)
06-11-10 11:11 AM
Quick Reply: 1992 es300 running rich
