po0306 misfire
Old 08-12-14, 06:26 AM
kakollmann
kakollmann's Avatar
Default po0306 misfire
i have changed all spark plugs/ coil packs/ o2 sensors / maf/still missing?
Old 08-12-14, 07:15 AM
Nelexus88
Nelexus88's Avatar
What year and mileage?
Next steps would be a compression test and swap injectors.
Old 08-12-14, 09:38 AM
01LEXPL
01LEXPL's Avatar
Oil control valves...
Old 08-12-14, 02:07 PM
lostape45
lostape45's Avatar
+1 on what 01LEXPL said. That was my issue, and that fixed it immediately. Which cylinders are misfiring? That determines which bank you need to replace
Old 08-12-14, 08:05 PM
01LEXPL
01LEXPL's Avatar
^ I'd do both.... its 100$ all in [from rockauto] and about 5-10 mins of your time.
I was in the same boat, changed three coils, two drive cycles later - again! Did my reading on the internet, and here. Turns out it was the OCV's.
Sucks to hear you went through all of that... you aren't the only one either, there's many threads like this where guys' spent all this money yet it requires a quick fix [in most cases anyways]
Old 08-12-14, 08:41 PM
NotADood
NotADood's Avatar
Lexus master tech here,
I hope the OCV's fix your problem, but I have seen valve guides needed to be replaced on the 2007 ES model. Just an FYI. Best of luck.
rosen71
RX - 1st Gen (1999-2003)
03-15-16 04:30 AM
davidm190
12-16-15 04:37 PM
crwys
11-25-13 02:30 AM
IndyRX300
09-26-11 08:49 PM
BLK13X
Performance & Maintenance
15
01-22-06 10:52 PM
Quick Reply: po0306 misfire
