95ES300 O2 Bank 1 Sensor 2
Old 07-19-14, 07:17 AM
hooterbif
hooterbif's Avatar
Default 95ES300 O2 Bank 1 Sensor 2
I am replacing my Bank 1 Sensor 2 O2 sensor with this:
Amazon.com: Denso 234-4623 Oxygen Sensor: Automotive Amazon.com: Denso 234-4623 Oxygen Sensor: Automotive
The connector seems to be under the driver's side seat for a later (2000) model:
http://www.justanswer.com/lexus/69oe...nsor-find.html
Is that true for the 1995 model?
Old 07-22-14, 10:29 PM
LexusElite
LexusElite's Avatar
Bank 1 sensor 2 will be after the catalytic converter, climb under the car and see if the wire harness goes through the floor board.
Old 07-23-14, 06:23 AM
hooterbif
hooterbif's Avatar
I did, and it goes into the floor of the passenger side.
I took the passenger seat out, cut the carpet, and found the connector right next to the edge of the center console. It was then easy to disconnect the connector and feed the cable through the hole.
SMUChris
12-17-12 03:50 AM
Avarec
IS - 1st Gen (2001-2005)
02-19-11 06:51 AM
mrchacon
06-26-09 05:22 PM
morris
Performance
04-18-08 04:26 PM
ynvme
05-28-06 08:01 PM
Quick Reply: 95ES300 O2 Bank 1 Sensor 2
