Noisy Pulley - Concerning?
All, I've noticed that there is what I would call an abnormally loud gear noise coming from the following location under the timing belt cover. Its almost like it needs a shot of grease or a good showering of WD40...Has anyone else had this noisy condition with their ES300?
Mine is a 2000, 83k miles and the Timing Belt was replaced (as per the sticker on the cover) at 36k miles in 2009 so apparently someone replace the belt due to time.
Any thoughts appreciated.
Yep sorry there's no video but I can say that it nearly sounds like metal on metal when the engine is running. That said, and assuming correctly in this case that a cam bearing needs to be replaced, is that a pretty big job or not? Though I do most of the maintenance on the car myself, this would not not be something I can do myself for sure. Again thanks for your response.
Try pressing on the cam cover (to create a better seal) when the engine is running to see if the noise gets softer. If it does that means it's coming from the timing belt components not internally to the engine. BTW my car makes the same noise I've been unable to figure out what it is.
This might seem silly but it's a very good idea. It works suprisingly well. I personally prefer to use a metal tube but my hearing is .... not great.
Thanks MrBooby for the insight!
acarapella
20
01-12-18 06:06 PM
