i keep hearing a clunking sound
Old 06-19-14, 10:17 AM
sereousl
sereousl's Avatar
Default i keep hearing a clunking sound
When i made a sharp turn i hearing a clunking sound. I hope thins isn't another problem to be fix but if hopefully it'll cheap
Old 06-19-14, 10:40 AM
mitmaks
mitmaks's Avatar
Could be CV axle joint.
Old 07-05-14, 06:05 AM
TOLex168
TOLex168's Avatar
Check and tight every nuts/bolts from control arm to rotor, that is the cheapest way. Make sure the sound it is not from your steering wheel/column.
Old 07-05-14, 07:23 AM
BDSL
BDSL's Avatar
Things to check:
- tie rods
- ball joints
- lower control arms
- strut mounts
Old 07-05-14, 03:18 PM
ES300NZ
ES300NZ's Avatar
Things to check;
Wheel Bearing,
Wheel Nuts,
Brake Pads ( they can move in the caliper if cheap non OEM one's).
Play in lower arms,
Shock Knock: shocks moving inside the strut, rock car from side to side on the ground violently listen for knock, or place hand on strut and 'feel it'.
Old 07-06-14, 10:04 PM
jegyed
jegyed's Avatar
Default Clunk when turning right slowly and vibration over 70
I have the same issue- a clunk when turning right at slow speed, and a vibration over 70mph. Both on the right side.
Old 07-07-14, 05:59 AM
speedkar9
speedkar9's Avatar
I've got the same issue on my Solara. Clunk when turning at low speed, more evident if there's passengers in the car, and a vibration at high speed (but that could be wheel balance).
I checked everything for play and noise thoroughly this weekend and couldn't find anything loose or where the noise is coming from. I know my right side ball joint leaked out all the grease last year but its still taught.
I think the next thing is to check the steering rack and intermediate steering shaft / U-joint.
Old 07-16-14, 08:10 PM
jegyed
jegyed's Avatar
Default Would it be just the lower control arm?
I inspected everything and found the control arm bushing to be shot. Everything else seemed Ok. Could it be that simple ?
Revived
05-20-16 09:19 AM
kg19989
09-15-10 10:44 AM
jdm93400
Suspension and Brakes
06-07-09 03:00 AM
Doc Yota
04-20-09 09:47 PM
JaredB
GS - 1st Gen (1993-1997)
10-14-06 02:15 PM
Quick Reply: i keep hearing a clunking sound
