1999 Lexus Bucket Seat Wiring?
Can anyone identify which color wire is for which function from the picture below? These wires are from the driver side front bucket seat of a 99 Lexus es300. The passenger side wiring has one difference. For the passenger side, instead of the red with yellow stripe wire, there is a solid black wire. That is the only difference. You can click on the picture to enlarge it. If anyone has a wiring diagram for this year and model, that would be nice. Your support is greatly appreciated. Thank you very much, Tommy.
Here you go, I am guessing you have a non-memory seat car with no heated seats? There would be more wires there to support those functions if you did have them. Also I can't match up the black and white/black on the passenger's seat. It sort of makes sense since you don't have a seatbelt buckle reminder on the pass side. These cars were sold in Japan as RHD Toyota Windom, and some of the wiring is there for those functions, so those extra wires on pass side might be a buckle reminder for the RHD car, unused on the LHD ES300. This is typically how the factory service manuals (where I got the info from) work, if there are unused wires they simply aren't documented.
Hope it helps!
Large Blue/White (+) to seat adjuster
Large White/Black (-) to seat adjuster
red/yellow (buckle switch signal)
white/black (buckle switch (-) ground)
Yellow/Red (airbag)
Yellow/Green (airbag)
Hope it helps!
Yellow/Red (airbag)
You are simply Awesome! Yes, these seats will be installed in a Project car. This is just the info I was looking for. I want to thank you so much for your outstanding support and also thank Club Lexus for their support as well. Aloha, Tommy.
Luxor
06-11-24 08:15 PM
