ho do i replace the stabilizer bar link & canister vent valve
Old 10-25-13, 04:28 PM
albertldee
albertldee's Avatar
Default ho do i replace the stabilizer bar link & canister vent valve
the dealership reccomend it replace cause i felt a pulsation in the brake when i make a left turn and my engin light came on dealer said the error is from a bad Canister vent valve that need replace i dont know where either is on my car is there a schematic for it
dealer price
STABILIZER LINK (48810-06030 (parts) $104.86
STABILIZER LINK LOCK NUT LEFT (90080-17227) (parts) $19.92
Labour $176
Canister vent valve 90910-12271 (parts) $135 (labour) $76.91
Old 10-25-13, 10:36 PM
PuReChaos
PuReChaos's Avatar
I wasn't sure whether you were dealing with the front stabilizer or rear, but they are the same. In the diagram the only part you care about is step 1 and 2.
As for the canister vent value, sorry but I can't find any diagrams for you.
Old 10-26-13, 07:28 AM
albertldee
albertldee's Avatar
it's the front thanks apreciate it when i make a left turn while my foot on the brake i feel a pulsation and grind in the brake thie only happen when i make a left turn and my foot on the brake the dealer said it's the brake that's gone and the stabilizer link so i'm wanted to replacement
do i need to do a wheel allingment when i change it
Old 10-26-13, 09:53 AM
PuReChaos
PuReChaos's Avatar
As far as I am aware, no you won't need an alignment, however, if someone knows different hopefully they'll let you know, because i'm not 100% sure. You only need an alignment after doing things like tie rod ends, arm shafts, struts, etc.
Old 10-26-13, 11:07 AM
tomf
tomf's Avatar
What year and model is your ES?
Old 10-26-13, 01:09 PM
albertldee
albertldee's Avatar
sorry front 1997 es300
Old 10-26-13, 01:37 PM
BDSL
BDSL's Avatar
That is correct. You only have to do alignment if you mess around with tie rod, ball joints, lower (and upper) control arms, struts, etc....
Old 10-26-13, 01:38 PM
BDSL
BDSL's Avatar
You don't need an alignment if you are doing brakes and sway bar end link.
Old 10-26-13, 01:40 PM
BDSL
BDSL's Avatar
If your stabilizer link is bad, you will hear knocking when going over bumps.....not vibrations when braking.
Best is to replace the brake pads and rotors first. Then see if the noise is still there.
Old 10-26-13, 05:01 PM
PuReChaos
PuReChaos's Avatar
Sorry but you answered your own question by quoting me
Old 10-27-13, 07:57 AM
tomf
tomf's Avatar
I think the part you mentioned, Canister vent valve 90910-12271, is the VSV for the charcoal canister shown in this attachment. From the diagram it looks like it would be easy to replace. It appears to be near the air intake where the air filter is located.
Attached Thumbnails ho do i replace the stabilizer bar link & canister vent valve-vsv-for-charcoal-canister-97-lexus.png
Old 10-27-13, 08:09 AM
tomf
tomf's Avatar
The hard part about replacing the stabilizer link is getting them off because their nuts become rusted and there is no way to hold the bolt to unscrew the nut. I usually end up cutting them off. Other people have had some luck using vise grips. If they are not too rusted and too loose an impact wrench will work.
The bolt has a hole in the end for an Allen wrench to hold it while the nut is turned with a wrench. In my experience, the nut is usually too rusted for this to work.
Old 10-27-13, 08:15 AM
tomf
tomf's Avatar
BTW, Amazon has the VSV for about $30.
http://www.amazon.com/Dorman-911-602-Vacuum-Switching-Toyota/dp/compatibility-chart/B003P9US2I http://www.amazon.com/Dorman-911-602-Vacuum-Switching-Toyota/dp/compatibility-chart/B003P9US2I
Do yourself a favor and replace it yourself.
Old 10-27-13, 08:59 AM
BDSL
BDSL's Avatar
There is a Allen key hole on the studs of the link. You have to insert an Allen key to hold the stud in position while turning the nut.
Old 10-27-13, 09:36 AM
mitmaks
mitmaks's Avatar
Vent valve
http://www.ebay.com/itm/DORMAN-911-602-Emission-Vacuum-Valve-Vacuum-Switching-Valve-/271295166129?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f2a73b6b1&vxp=mtr
sway bar links
http://www.ebay.com/itm/TOYOTA-CAMRY-1997-2001-SWAY-BAR-LINK-KIT-4PSC-FRONT-REAR-BOTH-SIDES-/190942479451?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c750f045b&vxp=mtr
Quick Reply: ho do i replace the stabilizer bar link & canister vent valve
