97 es300 misfire P0302
Old 09-03-13, 05:35 PM
New97ES300
New97ES300's Avatar
Default 97 es300 misfire P0302
Hi everyone! My CEL came on a little while ago, and its giving me the P0302 code... after doing some research on this forum, i switched the coil and the plug from a different cylinder to see if that fixed the problem..No Dice :/ I also put some seafoam in the gas tank to see of maybe that would clean the injector... I didn't put any in the vacuum hoses, because i don't know how to identify the correct vacuum hose that everyone keeps talking about! haha
The car has a very rough idle in neutral, 1st and reverse. If anyone could help me out on what i should do next it would be greatly appreciated. Thank you!!!
Also, thanks for all the other resources on this forum. I have learned a great deal from reading other posts!
Old 09-04-13, 08:57 PM
yeskay
yeskay's Avatar
need more details. did you replace the cylinder 2 coil/sparkplug. did you get any other codes besides 0302.
Old 09-05-13, 02:17 PM
New97ES300
New97ES300's Avatar
i ended up putting a new coil and plug into the cylinder but that didn't fix the problem.
Yes as a matter of fact i did get another code, P0773 a shift solenoid. I really dont know anything about that either
Cleeriv777
03-23-17 05:45 PM
Billiamch
04-11-16 01:31 PM
dandog96
17
02-14-16 12:27 AM
jc2005
05-10-14 06:24 PM
coffin1333
01-16-14 03:24 PM
Quick Reply: 97 es300 misfire P0302
