97 ES300 wont shift out of 1st after messing with TB
Okay I'm new here. Been using this site for a bit and always got a lot of help searching.. Hopefully I'm posting in the correct section!..Unfortunately, I think I created my own problem and one I havent seen any answers. So here it is..
Short version:
The car was working fine other than some stalling so I decided to clean out the IAC valve. Cleaned it up, got it back together and idling right, but now the car will not shift out of 1st gear.
Long version:
Here's a little more detail as I'm pretty confident I screwed something up When I took it apart, I got a little sloppy. Took the bottom plate off the IAC valve and notice there was a spring in it. When I put it back together apparently I put it on reverse cause the car was idling at 3000RPM. Once I figured this out and corrected it was idling pretty close, but I adjusted the Throttle Position Sensor cause like a dummy I had taken this off. I broke the first TPS sensor so I replaced it.. Anyways, thought I got the idle fixed, but then the car would not shift out of 1st. I adjusted the throttle cables and still couldnt get it to shift. So that's where I'm at now. I've looked around a lot to see if I unplugged or messed up anything obvious. So far nothing, so I'm thinking the IAC or TPS .. or something else may affect shifting?
Thanks for any help or suggestions!!
Sam
Short version:
Long version:
Sam
Short version:
Long version:
Sam
Short version:
Long version:
Sam
Very good point as I was pretty confident that is where I screwed up.. There are two cables and the one that has a red stripe I assumed was to the transmission. Since I noticed I tensioned these back exactly where they were I tried to get it back.. then went tighter..looser..back to tight. Did this probably 10 times, test drove after each and nothing. How sensitive are those cables? I'm wondering if there is something else I could have done other than the tension..
PDXLex
04-12-15 03:09 PM
norcalvp
20
10-13-12 05:42 PM
