Trouble Codes p0110,p0100,p0115,p1730
Old 05-15-13, 12:45 PM
BostonVP
BostonVP's Avatar
Default Trouble Codes p0110,p0100,p0115,p1730
I now encounter for a few more situation after replacing the vehicle speed sensor. Before i did that, i cleaned the throttle body with some valvoline throttle cleaner spray. I put everything back together including the vss and went out for a test drive. During the test drive i notice that the abs brake was kicking in time to time by it self, slowing the car down (think it grabing on the brakes not sure) than it would release and so on. I figure i drive around a bit and see if the problem would go away, but it wasnt, so i drop by autozone and had the vehicle check out. So had the vehicle scan and code p0110, p0100, p0115, and p1730 showed, which was never found before replacing the vehicle speed sensor.
Old 05-16-13, 01:01 PM
BostonVP
BostonVP's Avatar
Okay i figure the problem with the codes, it seems like when i cleaning the throttle i forgot to plug in the MAF properly, so now everything is fine except for the one of the code, which is the p1730. I acutally tried to clear the code, but that didnt work. Can someone help me out on how to fix this?
joeyfres
IS - 1st Gen (2001-2005)
12-05-16 06:43 AM
RXGS
05-06-16 08:35 PM
koolcat
Performance & Maintenance
03-16-13 12:06 AM
CJRUBIO29
01-24-09 01:01 AM
buggen
03-05-07 11:58 AM
Quick Reply: Trouble Codes p0110,p0100,p0115,p1730
