Is it safe to re-use the Hydraulic Tensioner?
Has anyone re-used theirs?
Or should I stop being cheap and buy a new one along with my timing kit?
I've re-used them several times and not had any problems. But the key is to carefully inspect for leaks, if you see anything that looks like oil under the boot, replace the tensioner. The safe thing to do is just get a timing belt kit that includes the tensioner. But get the kit that is all OEM parts, if you put in aftermarket you'd probably be better off just using the original.
Thanks for the feedback guys.
I've re-used the hydraulic tensioners in my '97 since it was a non-interference, but my 4es is a different story...
I seen kits with and without the tensioners so I wasn't sure the importance of them being replaced.
But ill def. Pick one up anyway for that peace of mind.
Thank you
Thank you
I also have a 97. I have re-used the tensioner twice. Important thing is check for leaks. There is a procedure for checking in the shop manual. I replaced mine at 300k km (187k miles).
I noticed a good majority of people re-use their tensioners. I've re-used them on my '97, but I'm a little skeptical considering my 4es has an interference engine.
DshngDaryl
06-01-17 12:17 PM
