HELP, Spark plug replacement on a 2002 ES300
How difficult is it to replace the spark plugs on a 2002 V-6 ES300? Does the intake have to come off? Any advice or comments are appreciated.
Thanks
Cliff
Thanks
Cliff
Do a search before posting. Here's a thread on spark plug replacement for the 4ES:
https://www.clublexus.com/forums/es3...ent-es330.html
The front plugs are quite easy. The rear plugs require that you take off the intake plenum. Make sure you replace the plenum gasket, and tackle the PCV valve while your back there.
Its the same process as the Camry V6:
speedkar9
12
06-14-13 08:11 PM
masboy
05-19-09 02:08 PM
