Air Bag Light
Old 06-18-03, 07:51 AM
jcboiz
jcboiz's Avatar
Angry Air Bag Light
Someone who knows how to disable the light please let me know. I have a 92 ES300 and the AIR BAG light is on constantly. I am pretty sure that it is a maintanence type thing, where you go into the dealer and they check if the air bag is working properly and then they do something to make the light go away. Does anyone know how to do that? Thank you for all your help.
Old 06-18-03, 06:36 PM
steviej
steviej's Avatar
didn't you state you were selling the car?
I think you may be infringing on some law here.
Don't jeapordize the safety of the car (or the potential buyer).
Get it checked by a qualified person.
In the meantime, check the fuses.
steviej
Old 06-18-03, 10:55 PM
jcboiz
jcboiz's Avatar
very true. I might as well take it to someone qualified and check everything before I sell it. Thanks for your help.
Old 06-18-03, 11:23 PM
Toysrme
Toysrme's Avatar
In my 92-93 Camry service book it must say 5,000 times in the first 10 pages.
If you disconnect the battery for any legnth of time it'll discharge the backup power for the airbag.
Take it to a dealer and have them reset it. It takes a "scpecial tool" to do it.
Old 07-01-03, 08:33 PM
LexDiamond
LexDiamond's Avatar
Not true.You need to replace the airbag control computer which is located under the center console its 2 huge yellow plugs just make sure u remove the battery first then swap it out and violia! It's gone call a parts/junk yard a 92 style can be had for $75 easily. I am a pro at these I've done at least 5!!
Old 07-12-03, 02:33 PM
skperformance
skperformance's Avatar
when you say 2 huge yellow plugs do you mean the harnesses?
there is a way to reset and clear the code
which involves shorting 2 pins on the diagnostic plug and grounding them in intervals
but if it is on then it is more than likely that you have a problem that needs to be fixed
Old 12-16-12, 09:49 AM
canucklehe
canucklehe's Avatar
my airbag light is always on, on both my 93 ES300 parts car, and also on my 93 ES300 daily driver. what can I do to re-set it?
which plug do you speak of skperformance, and what are the grounding intervals? If there is a problem with airbag module, won't it just trip the ABS light again? I did just have battery out when I re& re'ed the cluster.
Old 12-16-12, 06:54 PM
Hayk
Hayk's Avatar
canucklehe, if you want a response from the original poster, you probably won't get it. You have to keep in mind that this thread is from 2003 and most of the userbase has changed drastically. You could try a Personal Message, but you never know if they even check them.
Old 12-16-12, 07:41 PM
canucklehe
canucklehe's Avatar
DOH!! I am trying to use the search engine to minimize extra posts (a lot of people flame you for re-posting stuff that has been asked before). maybe I should ask this question in a new topic. this one seemed to be the best hit.
I thought it was '07 (oops, that was July). either way...it's still pretty old, isn't it?
RWC SC400
SC- 1st Gen (1992-2000)
48
01-06-21 06:53 PM
ohiois350
02-13-18 07:12 PM
Jeanb
05-04-11 12:17 AM
UR2klose
03-07-09 10:31 AM
EastCoastES
11-18-02 05:42 PM
Quick Reply: Air Bag Light
