Any idea what model/year Lex wheel is from?
I guess I don't understand how this stuff works, or the specs are wrong that I read. Because the bore size is supposedly smaller on the ES250, which would make the wheel impossible to fit. You can find the center caps on Ebay, search for ES250 center cap. I think the LS400 caps might fit but not sure.
The hub bore is a little less critical, a larger hub bore wheel will fit on a smaller hub, though one should use a hub adapter ring if the wheels are hub centric. Then again that site with the wheels specs you linked lists the LS400 wheel as 16x7 but we know it was a 15" so maybe their specs are off.
Canuckle what does the wheel say, it should have some markings molded in like "15x6.5JJ 50" or something like that on it, should help you identify which wheel it is.
da-bizket
Wheels, Tires & Brakes Forum
04-26-07 11:07 AM
