2000 ES300 Brake/Rotor & Wheel Bearing Replacement
Anyone have any good advice, DIY instructions, details, schematics on doing a possible weekend job on the the brakes/rotor, and wheel bearings on 2000 ES300.
Thank you.
Thank you.
Back bearing is easy.
Once you have the rotor removed, you can stick a socket with extension through "hub / knuckle...whatever you call thing". It is held down by 4 bolts or nuts.
My advice is to make sure you've got brake lube, a wire brush and enough brake cleaner before you start.
Here's how the front brakes are done:
Rear brakes:
And parking brakes, skip to 3:17 where I explain how the bearing would come off:
Rear brakes:
hd54321
10-11-04 10:26 AM
