Grounding kit?
Old 01-03-11, 12:20 AM
Benbendx
Benbendx's Avatar
Default Grounding kit?
I was thinking about putting a grounding kit for my ES300. What's your guys option. Got any recommended companies?
Old 01-03-11, 12:37 AM
PFB
PFB's Avatar
What??????
Old 01-03-11, 01:25 AM
BoostedE21
BoostedE21's Avatar
Grounding kit...as in adding additional grounds for additional stereo equipment?
Wire is wire...just get some nice low gage wire with quality shielding.
Old 01-03-11, 06:35 AM
Benbendx
Benbendx's Avatar
Ground my whole car
Old 01-03-11, 06:38 AM
Specter
Specter's Avatar
Lowering kit ???
Old 01-03-11, 07:11 AM
Benbendx
Benbendx's Avatar
http://www.izvw.com/Guides/Grounding.aspx
Best way to describe.
Old 01-04-11, 06:47 AM
Specter
Specter's Avatar
Why would you need to keep electrical system to stay "stable" ?... How much more stable is the original wiring ?
Old 01-06-11, 10:18 AM
dcapo
dcapo's Avatar
dont think the brand would matter, just depending what gauge it is, i believe i have (4)4 gauge custom wires, still have to do the alternator but definitely u can feel the difference when idle and with electronics turned on, still need voltage meter to measure accurately
pic of chassis to engine- by coolant sensor passenger side engine mount
pic of chassis to motor/tranny on drivers side (closer view)
pic of chassis motor/tranny on drivers side (farther view)
pic of chassis to motor/tranny on drivers side (by intake/drivers strut mount)
my source diy
http://www.j-body.org/forums/read.ph...13629&t=113629
http://www.j-body.org/forums/read.ph...=133158#133158
Old 01-22-11, 10:47 PM
Benbendx
Benbendx's Avatar
You didn't do a negative to the chasis?
Old 01-24-11, 08:52 AM
dcapo
dcapo's Avatar
do u mean from negative terminal straight from the battery to the chasis?
then no, i ididn't but i will now , still felt a slight bit better throttle response with the grounds i've got
Old 02-13-11, 08:15 AM
adreano17
adreano17's Avatar
hey, i know im late but ran across this, it may be worth a look. its JDM http://www.l-tunedparts.com/product/?id=638
Old 02-13-11, 10:56 AM
Benbendx
Benbendx's Avatar
I just need someone to help me put it in
Old 02-13-11, 08:11 PM
ASG14
ASG14's Avatar
****! I totally forgot. I've been goign through absolute hell with cars the last few weeks. You don;t want to know.
I should be able to do it in a couple weeks for you. Sorry.
Old 02-14-11, 12:35 PM
LiCelsior
Retired
LiCelsior's Avatar
grounding kit is SO easy to do. i did the Big 3 upgrade on my vehicle plus a couple extra just in case. just buy ur own wire and do it, i ordered 4GA from ebay and it was around 20bucks for 8ft and a bag of 4GA o ring terminals was around 8 bucks.
AC1984
Performance & Maintenance
04-29-13 09:23 AM
LexISGS300
GS - 1st Gen (1993-1997)
04-15-12 07:43 PM
3rdelement
08-09-05 10:12 AM
41
07-19-05 08:39 AM
sevens
06-17-05 12:14 AM
Quick Reply: Grounding kit?
