95 es300 ... wont start but cranks
started w/ jumping dead battery due to headlights being left on. key was in accessory position. had some small sparking when connecting, but it didn't seem like much but it was enough to blow the 100 amp fusible link and a couple other fuses. i replaced all those, and checked every fuse in the car. now engine will crank but not run. all lights, windows, radio and door locks work.
anything else i'm missing?
thanks.
thanks.
www.camrystuff.com
They have pdf manuals for Camrys, but we all know what an ES is at heart...a Camry.
i swapped the efi relay with the other just like it and nothing .... i cant hear the fuel pump.
i guess that leaves the main ecu and/or fuel pump ecu?
That would explain why it takes me 6-7 cranks to start...
alot of times the fuel pump will come on for 5-10 secs when you first turn ignition switch to "on", then it shuts off until its running. does anyone know if there is a jumper in diagnostic terminal to keep fuel pump on? i have a 1990 toyota pickup that i can do that to....
gpshogan
10-18-12 09:32 AM
