95ES300 grinds when starting if i crank too quickly.
Old 05-02-10, 04:16 PM
immax01
immax01's Avatar
Default 95ES300 grinds when starting if i crank too quickly.
For the past few months, my car makes a grinding noise when i try to crank it. Ive discovered that if i wait about 10 seconds after i turn the key to on, then try to crank, it usually doesn't grind, it starts just fine.
What happens in the few seconds after i turn the key to on that would cause the grinding to go away?
If i put the key into the ignition and turn it to start immediately, i always get this grinding/buzzing noise. I appreciate any advice.
Old 05-02-10, 04:31 PM
BDSL
BDSL's Avatar
Maybe a bad starter.
Old 05-03-10, 02:22 AM
AgntTinkle
AgntTinkle's Avatar
So it doesnt start right away? you gotta crank it 2 or 3 times to get the car started?
If so, then bad starter.
Old 05-03-10, 05:20 AM
immax01
immax01's Avatar
Right, UNLESS I wait about 10 seconds after i turn the key to on. If i do that, then usually it starts just fine. This is where im confused. If the starter is bad, why would waiting to crank it solve the problem?
dc893
09-02-12 02:24 PM
andyman32
24
03-20-12 05:55 AM
LuxOut003
10-29-08 05:36 PM
sonyman
18
06-12-06 04:20 PM
Ice350
Performance & Maintenance
14
12-07-05 11:55 PM
Quick Reply: 95ES300 grinds when starting if i crank too quickly.
