how do you like your aftermarket hid?
Is the Helligkeit a good one to buy for my 2000 ES300? Which bulbs do I want for the whitest light? I don't want blue - just the whitest light I can get. I figured I'd just do the low beam headlights. Maybe I'll put Sylvania Sylverstar bulbs in for the high beams and fog lights. What do you guys think?
Lexucanafer
4300k are the whitest HID bulbs you can buy. The higher the color temperature you go, the more color you will see...AND...the less light the bulbs will produce. 4,300k produces a bit of blue color but is mostly white, but as you graduate to 5,000k and higher, the blue color becomes more and more pronounced and eventually looks almost purple at around 8,000-10,000k. Very blue or purplish colored HID bulbs actually produce much less light than your standard halogen bulbs. A total waste of money if you are looking to improve your road visibility. They may look cool to some, but are pretty useless for visibility, plus they produce excessive amounts of glare for oncoming traffic.
Lexucanafer
4300k are the whitest HID bulbs you can buy. The higher the color temperature you go, the more color you will see...AND...the less light the bulbs will produce. 4,300k produces a bit of blue color but is mostly white, but as you graduate to 5,000k and higher, the blue color becomes more and more pronounced and eventually looks almost purple at around 8,000-10,000k. Very blue or purplish colored HID bulbs actually produce much less light than your standard halogen bulbs. I total waste of money if are looking to improve your road visibility. They may look cool to some, but are pretty useless for visibility, plus they produce excessive amounts of glare for oncoming traffic.
Lexucanafer
Actually, 4,300k bulbs do have a slightly blue tint to them. I know because my HIDs are 4,300k and I can see myself the faint blue color. 5,000k are bluer yet. But you are correct that 4,300k are closest to OEM (stock) HIDs. That is because they produce the most visibility.
4300k, if anything is closest to yellow. 4300k is 4300k it should be 'pure white' no blue.
I have a feeling you have a 6000k kit like myself;
4300k is OEM/Whitest possible & pure white light; giving you widest range of light, further visibility.
Sure, Sylvania's are good.
See my pic below. I didn't bother with the DRL/Highbeams since it would be plain stupid. Each time you crank the car over even in 'off' mode, the car would start up with the highbeam's 'on'. HID's don't like being cranked over when on... And they don't last as long that way.
So yeah, i would go the silverstar method in those.
That could be the problem. HID's don't work the same way as filament bulbs. HID's use an arc to generate light. Some corrosion might cause some flickering. It won't happen with filament bulbs because they don't turn on and off instantly like an HID's arc. If it were me, I would replace the sockets and use a relay kit. I think that would solve your problems. I guess you could try using a different HID kit, but you might run into the same problems.
I agree with R1R. It's safer to go with a relay harness.
I had the opportunity to go with 4300k but choose 5000k because they produced the whitest light. Here are some pictures of mine after I installed them. They were taken on a camera phone, so the whole headlight area is whited out by default on the camera because it was too bright to capture an image. That's fine, but what you want to look at is the surrounding area's of the light from the headlight, that's a pretty accurate representation of the color of the 5000k headlights, a very slight blue tint.
Thanks 01LEXPL - if only the Hellikeit sight was working I'd order 'em now. It doesn't seem to allow me to pick which bulb I want. Are there any other brands that come recommended?
Thanks, Martin
Thanks, Martin
If you want the whitest light with the most lumens, get 5,000k. Factory is 4,300k, it will have a very slight hint of yellow, but it will output the most lumens on the road. 6,000k has a slight blue tint to it.
